Author Topic: Coil On Plug Conversion (pic & vid)  (Read 2867 times)
peerless
« on: May 30, 2008, 02:38:31 PM »
Just wanted to show off our latest on the M42. We did the coil on plug conversion and it was super simple and a great upgrade.
Problem with stock setup is the spark plug wire are subjected to a lot of heat from the factory headers. This causes them to fail more often and the wire set if not cheap.
The coil on plug conversion consists of 2 studs, 4 nuts, 8 bolts, mounting plate and 4 M5x coils. (not exactly sure what coils as the customer supplied them)
Mark your 4 original coil connectors, remove coil pack and wire set. Remove 2 original valve cover bolts and replace with studs. Lay in the mounting plate, install your new coils, make a 1" cut in the factory harness and plug in the coils, start engine. Done!
Here is a picture and a video. The whine you hear is from all brand new timing components and engine.
Robert
www.e30motorwerks.com
(714) 398-8405
nuvolarossa
« Reply #1 on: May 30, 2008, 03:23:51 PM »
starting to love that yellow :) great job!
that whine seems a S/C :)
great to see a better than brand new engine!
ClodKing
« Reply #2 on: May 30, 2008, 03:38:15 PM »
I've always liked the black on yellow. That engine is really really nice.:D
