NO! adjust the collar on the prop to get the prop out of the way, i'd imagine that's what's causing your bolt-up problems. try bolting the diff up without the prop at all first, then try with the prop. the prop will need to be shortened at the collar, please don't drill a perfectly good subframe and throw your thrust angle etc out!
A medium case diff will fit with no drilling subframes required. i have one in mine. nice diff btw, looks lurrvely.
i have to shorten the propshaft!? i dont see why, on both the diffs the input flange sticks out the same distance from the bolt pattern... it really looks like the only thing that doesnt line up is the output flanges which isnt a big deal... i put it on without removing the shaft because i didnt want to remove the exhaust to get at the collar, its a pita to remove my exhaust. i just slid the diff onto the knurled bolts on the propshaft and then lined up the bushing.
If it's a 4.10 Ltd Slip, you should also see the elusive "S" markings on the top and bottom of the diff. See picture of my medium case 4.10 below:
Yes sir its exactley one of those. i painted over the top 'S'.
just drill upper holes closer about 1cm to others holes and it should fit. And check does the bolts screw freely in to differential. After that fit E36 gearbox
so drill which holes? on the subframe or on the diff? the thing is its not misaligning by THAT much (whole cm) cause when its up there with my finger i can feel the hole and its almost right on for all four but for some reason the diff wont snugly sit up against that support from the underside.
We finally saw the marks on the driveshaft and put 1/8" spacers between the diff and the subframe, fixed it compleately.
That right now sounds like exactley whats missing... something to fill the space between the diff and the subframe at the bolt holes because like i said above, it just wont snug up to it. when you forced it in the first time you must have somewhat deformed the subframe to the shape of the diff but at the same time bent it upwards causeing the propshaft to hit the chasis?
thanks for all the advice guys! i'm goin to go give it another try now with my buddy hopefully we figure it out (: and ill post more pictures when i get to work
