Author Topic: question about superchargers  (Read 3044 times)
sand_m4n
« on: May 21, 2008, 07:16:28 PM »
Ok so my friend has offered to sell me his eaton m90 supercharger for 230 bucks  . my question is can i get it to work on my E36 318i and if so what modifications would i need to make? Also any idea how much power i would be making with one of these bad boys? thanks for all the help guys
Cheers!
« Last Edit: May 21, 2008, 07:25:19 PM by sand_m4n »
sand_m4n
« Reply #1 on: May 25, 2008, 11:47:50 AM »
guys im begging for some help here i really need to know if it will fit. please bestow upon me wisdom from your vastly superior knowledge of FI
colin86325
« Reply #2 on: May 27, 2008, 12:27:46 AM »
Might want to check the Supercharging forum on E30tech.com, but no guarantees as it's an E30 site.
futron.sim
« Reply #3 on: May 31, 2008, 07:47:52 AM »
Oh M90, I am also in the process of fixing a M90 onto my E36 318is. I am still planning for my custom intake manifold etc.
I believe there are 3 main things you will need to look into:
1. Crank pulley. Not all engines come with serpentine pulley (esp. for crank pulley). For my case, its a V-belt pulley thus it will have to be replaced. Since power steering and alternator runs off the crank, it will have to be replaced as well.
2. Custom intake manifold. If you are going to mount the blower the same way as the DASC, you will need to fabricate an intake manifold. You will also need plumbing charger air intake, throttle body etc.
3. Piggy back or new ECU or reflash ECU. You can't use the stock ECU with stock mappings. It will have to be reflashed with tuned settings or use a piggy back like Unichip, Emanage etc.
These are optional things I am looking into as well:
1. May replace stock gasket with a cometic stainless steel gasket for security purpose.
2. If running high boost of ~10PSI, intercooler is recommend as the air coming out of the blower will become very hot.
3. Replacing the stock injectors and fuel pump with bigger ones. Currently, I am using the pink-top M3 injectors rated at 21lbs. I don't think it will be enough at high boost thus it may have to be replaced. The stock fuel pump may not supply enough fuel as well.
futron.sim
« Reply #4 on: May 31, 2008, 07:48:58 AM »
For the power, I am hopping it will hit over 200WHP but most importantly, a massive improvement in torque.
