List your mods or upgrades to your M42
Author Topic: List your mods or upgrades to your M42  (Read 5871 times)
Cobra Jet
« on: May 16, 2008, 09:31:22 AM »
I'm just curious to see what all of you have done to your M42's as far as improving over the original design for the engine, exhaust and suspension...
My 318ic = bone stock.  :cool:  I've only had it for a couple of months and am still going through it as far as debugging it & fixing minor things, but it will eventually be de-virginized...  :D
What mod made the largest improvement over stock?
What mod do you regret?
- Phil
1994 Cobra coupe #0013
2011 Genesis Coupe
2011 Tucson GLS
biglar
« Reply #1 on: June 02, 2008, 04:21:46 PM »
so far...
power chip
CAI
weight reduction
Suspension to come
2005 M3 6MT Silver Grey
1991 318i with 4.10 LSD
http://www.clutchstopper.com
Nivola
    • http://www.nivola368s.com
« Reply #2 on: June 02, 2008, 06:07:31 PM »
I'll bite... ;)
Accessories (OEM):
◦ Euro grille
◦ Evo/DTM type hood and deck lid seals (In Transit)
◦ Oil-bag
◦ Rear head-rest kit
Aftermarket Accessories:
◦ Fire extinguisher
Brakes:
◦ ATE SuperBlue
◦ UUC slotted front and rear rotors (In Transit)
◦ UUC stainless steel brake lines (In Transit)
Drivetrain:
◦ 4.27 LSD
◦ AKG Motorsport DTM quick shifter
◦ RedLine MT90 in differential & MTL in transmission
◦ Rogue Engineering Transmission Mounts
Electrical:
◦ AKG Motorsport DTM mono-wiper
◦ Euro ellipsoid projector headlights w/ smoked urethane shields (and shields for fog lights)
◦ Hella H1 55W low-beam and H1 130W high-beam bulbs
◦ Smoked side-markers, turn-signals and taillights
◦ Stebel Nautilus full-size Italian air-horns
Engine:
◦ Bosch 0280155700-FVE Design III 19# injectors
◦ Coil-Over-Plug (COP) conversion w/ high-capacity plasma coils
◦ Custom cat-back exhaust
◦ E.A.T. Ultrachip, 91 octane
◦ Elf Excellium 10W50
◦ K&N filter
◦ NGK BKR6EIX Iridium spark plugs
◦ OEM clutch fan delete, replaced w/ E36 318ti electric fan
◦ OEM complete timing chain/sprockets, chain-guide replacement
◦ Redline Water Wetter
Frame:
◦ Eric Jason design front steel skid plate (In Transit)
◦ Mason Engineering 1-piece TIG welded tubular steel strut brace
Steering:
◦ Momo Monte Carlo 350mm steering wheel w/correct BMW horn button
◦ RedLine Power Steering Fluid
◦ ZF shorter-ratio steering rack (OEM, for standard Z3)
Suspension – Front:
◦ Bilstein Touring Struts
◦ Off-set lower-control arm bushings (OEM, E36 M3)
◦ Urethane sway-bar bushings
Suspension – Rear:
◦ AKG urethane subframe bushings (In Transit)
◦ Bilstein Touring Shocks
Tires & Wheel Accessories:
◦ Sumitomo 195/65HR-14 HTR H4s
Track Gear:
◦ CG-Lock
◦ D-Force 15” x 7” rims (STILL IN TRANSIT!) :mad:
◦ Falken Azenis RT-615s: 205/50ZR15(F&R)
◦ Ferodo DS 2500 brake pads
If anyone wants further details, pictures, etc., check out my website:
My e30 318is "das Viereck" and my M coupe
Ciao,
Nivola
Correrai ancor più veloce per le vie del cielo...Nivola368s.com
Febi Guibo
  • m42 reporter
« Reply #3 on: June 02, 2008, 06:35:02 PM »
oh boy
suspension
H&R #29663 sport springs
Billy sport shocks
turner rear shock mounts
ST front sway
RD rear sway (got used)
treehouse CABs
stainless steel lines
7 series master cylinder
slotted / drilled rotors, new pads
ronal LS 15x7.5 wheels
BFG G-force sports
engine
MM 2130 cc motor (bored / stroked)
custom pistons (wiseco)
m47 crank
custom rods
M50 lifters, 6mm valves
custom intake manifold
Mark D chip (7200 rpm)
Lightweight flywheel (machined M20)
238mm sachs sport clutch
cams (loads of overlap)
there's some stuff I'm prolly missing
Electric fan
Cone filter
X5 shift lever
clutch stop
I'm sure I'm forgetting some stuff
ok, let's say I had to do it all over again (in a way, I do, because I'm in the process of starting a new car now):
to spare everybody the e-novel
LEARN TO DRIVE BETTER
I did skip barber, and its why I love the M42... save up, take the 3 day class, it will make a huge difference in your relationship to cars
DO BASIC MAINTENANCE
Get to know your car, power wash the engine bay and underside if you can, track down every leak, check every piece of rubber, clean, polish, repaint, fix what you can, replace what you can't.
GET YOUR ENGINE RUNNING RIGHT
Chain tensioner, oil pan bolts, timing chain noise, plugs, wires, coils, etc.
CLEAN YOUR AFM and THROTTLE BODY
ok, once that is set, I would do in the following order:
- Mark D. chip (easy instant gratification, and raising the rev limit gets you to 60 mph in 2nd gear, cutting the 0-60 time by a lot)
- Clutch Stop
- Learn to heel toe, double clutch downshift
- short shift kit, or at a minimum, replace every bushing washer etc. in the shifter assembly.
- 15" wheels (my personal preference)
- GOOD tires (makes a bigger impact than shocks and springs)
- LSD if you don't have one
- 4.27 LSD if you wanna be a little quicker
By this point you should be able to get a good idea about how you want your car to handle at the limit
- Shocks and springs (personal preference, but lowering the car a bit helps) I very much like my H&R #29664 springs a lot; very supple yet predictable
- sway bar you like (ST is good and cheap)
- Best brakes you can possibly afford
higher ticket items
- lightweight flywheel
- electric fan
- supersprint exhaust
all of the above will help the engine a lot; even though the M42 doesn't make a lot of power, having make peak power FASTER (eg, keeping as much momentum as possible between shifts)
The fan and higher flow exhaust... it's icing on the cake.
All the other engine mods, although I am an extremely satisfied customer of Metric Mechanic... it costs money and is therefore not for everybody.
The spirit of these cars is that they are mechanically simple, and allow almost anyone who **really** wants to understand driving dynamics to get in the game with a minimum of fuss.
Support M42club.com !!
« Reply #4 on: June 02, 2008, 07:09:54 PM »
Febi Guibo
  • m42 reporter
« Reply #5 on: June 02, 2008, 07:15:12 PM »
Quote from: tjts1;50495
yeah, that about got it right!
Choking Hazard
« Reply #6 on: June 03, 2008, 09:19:24 AM »
I've restrianed myself (well, really the bank restrained me from spending money I did not have) pretty well. I Bought the car two years ago.  Bone stock.  Did the bilstein springs & shocks, e-bay chip, don't-rmember brand rotors, 16 inch wheels, t-chain tensioner, oil pan bolt search, cheap-ass muffler, and thats about it.  In that two years, I've gone from 139,000 to 175,000 miles too.
[SIGPIC][/SIGPIC]-Scott
John W
« Reply #7 on: June 05, 2008, 09:38:42 PM »
Not much so far: K&N drop in filter, Mark D chip, Magnecor plug wires, Mobil 1Synthetic in the crankcase.
On the next oil change, I'm coupling the synthetic oil with this: http://www.oilextreme.com/ (Snake oil, I know, but I have seen too many dyno-proven results over the past 12 years to deny its benefits.)
Soon: Mild suspension upgrade: Bilstein sports, e30 M3 springs, e30 M3 cabs, new control arms, OEM offset upper strut bushings, new rear shock mounts. I already have most of these parts collected ...
Otherwise, I'm mostly going to leave it alone. This car is just a fun, reliable daily driver for me.
1991 BMW 318is SOLD :(
1976 BMW 2002 m20
2005 Ford Focus ZX-3
