Author Topic: clutch  (Read 2744 times)
250k318is
clutch
« on: May 16, 2008, 05:08:17 AM »
looking into replacing mine the car has 225...mi and with some track days comming im thinkin i may need to replace. any one know were i can get one that is an upgrade from stock and also looking for motor and trany mounts that would be an upgrade aswell.
strad
clutch
« Reply #1 on: May 16, 2008, 03:37:52 PM »
Upgrade would be a single mass M20b25 fly with an M20 clutch.  Otherwise just replace your clutch and reuse your dual mass M42 fly.  It's plenty strong enough for a stock M42.
250k318is
clutch
« Reply #2 on: May 17, 2008, 12:03:59 AM »
was going to go with a aluminum flywheel for the m42 so i dont have to modify anything thats why i was looking for an upgrade
beegeezy
clutch
« Reply #3 on: May 17, 2008, 02:14:24 AM »
Some m42's came with a single mass flywheel. Get one, and get it lightened if you want.
colin86325
clutch
« Reply #4 on: May 17, 2008, 11:07:30 PM »
I have a single mass flywheel, but you can't really take that much weight off of it.  It also uses a different clutch kit and flywheel bolts than the dual-mass flywheel.
