Author Topic: TO Bearing questions  (Read 2740 times)
E30nate
« on: May 13, 2008, 11:08:55 AM »
i am putting an m20 flywheel in, and was just curious as to if i could use the stock bearing, or even a 325 bearing, or is the 323 bearing the only one that will work?
quinn11m20
« Reply #1 on: May 13, 2008, 04:51:01 PM »
Hey can you put an M20 flywheel on an m42 motor. So if you can what your saying is that i can save money by acquiring a m20 flywheel from the junk yard and purchasing a clutch upgrade and installing them. So I don't have to spend @ 500 for a 10lb. aluminum fly from a performance company. Right?
E30nate
« Reply #2 on: May 15, 2008, 11:10:49 AM »
anyone know what i can use?
Wise Old Dog
« Reply #3 on: May 15, 2008, 02:43:14 PM »
IIRC, you use a M20 clutch kit on the M20 flywheel. That's what Metric Mechanic uses on their M20 conversion flywheel.
E30nate
« Reply #4 on: May 16, 2008, 01:33:03 PM »
Quote from: Wise Old Dog;49402
thanks for the info. i found out that all late model e30s use the same TO bearing, which makes it a lot easier since i just replaced mine. i just need the 325 starter or gear and i will be done.
Wise Old Dog
« Reply #5 on: May 16, 2008, 02:12:45 PM »
You could just put the M42 ring on it. With a slight amount of machining. Probably work out the same $$.
E30nate
« Reply #6 on: May 16, 2008, 02:57:02 PM »
easier to go to pick n pull and get a starter for $20. or just swap the pinion gear on the starter.
