Author Topic: Replacing Crank Pulley for my M42 engine  (Read 2719 times)
futron.sim
« on: May 12, 2008, 10:14:47 PM »
My M42 is an early model that uses V-belt for the alternator and power steering but serpentine for the AC compressor. Due to this configuration, I am unable to install a supercharger (it requires serpentine belt).
I have read that there are certain models of M42 that uses a full serpentine crank pulley (all accessories uses serpentine).
May I know if such a crank pulley does exist and can I just bolt it onto my engine w/o changing anything, esp. the harmonic dampener? Also, where can I find such a pulley?
Thanks!
Adam C.
« Reply #1 on: May 12, 2008, 10:54:36 PM »
is this in an e30 or e36?  im guessing a 92-95 318.  you need the pulley from an obd2 car i believe and it should bolt right up.  i just swapped my crank pulley for an obd1 e36 cp to fit my s/c.
futron.sim
« Reply #2 on: May 13, 2008, 05:16:43 AM »
Its a 93 e36. Thus the engine its a obd1 M42B18.
Do you mean that I could use the crank pulley from the M44 engine? Cause M44s are obd2 and only post E36s have them.
Adam C.
« Reply #3 on: May 14, 2008, 08:34:54 AM »
Quote from: futron.sim;49201
im about 85% sure that you can.
