DISCUSSION
Engine + Driveline
How long are the upper oil pan bolts?
Topic: How long are the upper oil pan bolts? (Read 2400 times)
haledj
Sr. Member
May 08, 2008, 12:21:51 AM »
I want to buy some new ones before i take my pan off and drill them for wire.
So, how long from the base of the head to the end of the shaft.
Also, the are M6X1, correct?
Buy M42 Coil On Plug conversion brackets!
[/SIZE]
peerless
May 08, 2008, 12:35:42 AM »
Officially they are 6x18, but I think you can settle with 6x20mm.
Your going to safety wire the inside upper pan bolts? Good luck with that. Little tube of blue lock-tite will do you just fine.
Robert
www.e30motorwerks.com
(714) 398-8405
beegeezy
May 08, 2008, 03:26:37 AM »
Holy crap, robert's on the 'club!
peerless
May 08, 2008, 01:17:33 PM »
Quote from: beegeezy;48912
Thats right biatch, stalking across the net for fun and fame.
Robert
(714) 398-8405
DISCUSSION
Engine + Driveline
