Author Topic: Sachs Boge vs KYB also?  (Read 3750 times)
nomad
« on: May 07, 2008, 05:56:52 PM »
So how do these stack up? Sachs are more expensive so I'd assume they'd be built a little better. I plan on doing HR Sport at the most aggressive. If i do anything else it'd be Spec E30 set up
SoCal, 318is: IT RUNS AGAIN!
Wise Old Dog
« Reply #1 on: May 07, 2008, 06:23:39 PM »
IIRC with the spec e30, you can only use Bilstein sports. That said, if you are going to lower the car, KYB and Sachs/Boge are not shortened as Bilstein sports are. I've had both and the KYB's are firmer than the Sachs/Boge but I don't know if one is built better than the other.
nomad
« Reply #2 on: May 07, 2008, 06:44:29 PM »
Yeah, what I meant was if I changed anything in the future it'd be switching everything out to HR race and B-sports.
so the KYBs are stiffer? I've seen some use KYB with HR sports and said it was ok.
