Author Topic: Bmw M42 Starter  (Read 4320 times)
vatos_p
Bmw M42 Starter
« on: April 29, 2008, 01:22:32 AM »
Hello ! i have a problem , my starter has started to do problems , not being able to start the car , i have to turn the key more than 5 times to get the starter to connect to the engine and start the car...
i want to change the starter , but can anyone tell me in what models did bmw fit the same startet with the m42 engine ?
thank you..
steer with the rear !!!
Bmw M42 Starter
« Reply #1 on: April 29, 2008, 04:10:57 AM »
check first the electric connections from your starter to the rest..
Wise Old Dog
Bmw M42 Starter
« Reply #2 on: April 29, 2008, 05:44:43 AM »
Check your starting circuit first. Sounds like your starter works, but is having a problem getting the juice. check your ground path from the starter to the block. It grounds through the mounting surface.
bmw327
Bmw M42 Starter
« Reply #3 on: May 04, 2008, 12:43:59 PM »
Don't forget to check the ignition switch, too...I have a funky one in my e34; you have to know the trick to start the car.
1991 318i
1938 327 Cabriolet (project)
Vladi
    • http://www.bmwzone.ro/forum
Bmw M42 Starter
« Reply #4 on: May 05, 2008, 05:48:23 PM »
The starter itself is the same on all e30's. Only the pinion is different.
vatos_p
Bmw M42 Starter
« Reply #5 on: July 31, 2008, 03:07:38 AM »
i have fixed the problem by installing a new cluch-gear into the starter...that was the problem....thank you.
