Author Topic: Test Fuel Pump Connection  (Read 3553 times)
txleadfoot
    • Google Profile
« on: April 18, 2008, 12:09:50 PM »
How do I test the electrical connector at the fuel pump with a multimeter?  I can't get a reading on any of my running 318s with the ignition on.
Cobra Jet
« Reply #1 on: April 18, 2008, 01:13:26 PM »
I'm gonna say do a KOEO test (key on engine off) - once you have the car on and there is power, you should be able to get a 12 volt reading at the connector IF power is going to it.  Set your mult-meter to "DC", then take the multi-meter leads and touch the fuel harness metal prongs within the connector...  if everything is fine, you should see some sort of read out on the multi-meter.
- Phil
1994 Cobra coupe #0013
2011 Genesis Coupe
2011 Tucson GLS
RED IS 91
« Reply #2 on: April 18, 2008, 03:43:23 PM »
Make sure your testing the pump leads and not the fuel guage leads.The two in the photo are the pump leads.
good luck
txleadfoot
    • Google Profile
« Reply #3 on: April 18, 2008, 05:57:04 PM »
I get nada.  Even tried using the chassis as a ground.  Also tried another working multimeter.  This is on 3 cars, two of which are running.  I'm stumped.  Yes, it's the wiring at the pump, not the fuel level sender.
Thanks for your help,
Shaun
« Last Edit: April 18, 2008, 06:01:30 PM by txleadfoot »
RED IS 91
« Reply #4 on: April 18, 2008, 06:37:41 PM »
Check your relay?
txleadfoot
    • Google Profile
« Reply #5 on: April 21, 2008, 09:49:10 AM »
Thanks for the help guys.  I discovered over the w/e that there is no juice to the fuel pump.  It appears to have been cut previously at the connector end, so I will start there.  Is that wire set part of a larger harness, or can it be replaced with a factory section?
« Reply #6 on: April 21, 2008, 06:30:07 PM »
IIRC, it is part of the whole harness coming from the front.
