Hey fellas,
I've been searching on here about AFM related issues and I still have not seen what I am really trying to inquire about...
The AFM - can this unit be taken apart to diagnose or clean? I have removed the top of the aribox assmebly w/ the AFM attached and I did see the eletrical element inside at the one end.
I know this element can be "cleaned" by using Contact cleaner (or other safe cleaner) - but my question is, can the actual AFM box or assembly be taken apart to check for other issues?
Is that huge metal box not serviceable? Can the actual AFM unit be separated from the metal assembly?
I saw one there were someone mentions seeing "carbon tracks" after "taking apart the AFM" - but I have not seen any threads describing or detailing how to disassemble the AFM unit itself... Where are these supposed "carbon tracks" and how can I see if mine needs to be throughly cleaned?
I looked inside of the metal housing where the air would pass through, but I don't see any carbon build up or any other build up inside of that part.
What am I missing?
I was also looking to see if there was a method of testing the AFM unit to see if it was functioning properly (proper spec'd OHMS), but I have come across a thread that shows how to test the AFM unit in that manner either... I have seen the thread where the OHM specs are laid out for the AFM, ICV, TPS, etc etc etc, but no direction as to how to actually test the multi-pin AFM connector or unit for OHMS...
I also read up on the fault code 1215 - which merely states that the AFM could be not functioning properly, that the wire harness to it could be damaged which would give the same code, etc... I just need a firm confirmation as to how to actually determine that the AFM unit IS definitely bad (non-operational), rather than wondering if it's the wire harness, the actual AFM itself, or something else related to it...
I also wanted to know if the AFM is affected by outside ambient temps - meaning if it's cold or hot, does it operate any differently or are there no operational adjustments/changes when this unit is functioning 100%?
Thanks, it's greatly appreciated!
