Author Topic: Junk in my tank!!!  (Read 4185 times)
Ricer318ic
Junk in my tank!!!
« on: April 17, 2008, 07:17:15 PM »
Basicly i have a lot of rust and what not at the bottom of my tank(car has been sitting for about a year) Whats the best way to get rid of as much as possible( Its cloged 2 fuel filters already) I dont want this stuff hitting my injectors.
bmwpower
Junk in my tank!!!
« Reply #1 on: April 17, 2008, 07:25:56 PM »
Quote from: Ricer318ic;47355
Drop the tank, open the tank and empty the junk out.
Junk in my tank!!!
« Reply #2 on: April 17, 2008, 08:53:59 PM »
drop the tank... that easy? i thought you needed to remove the subframe to do that?!
bmwpower
Junk in my tank!!!
« Reply #3 on: April 17, 2008, 09:48:19 PM »
Quote from: hoevesruperd;47367
Not sure, but I do know the best way is not always the easiest way. :)
colin86325
Junk in my tank!!!
« Reply #4 on: April 17, 2008, 09:59:34 PM »
There's an allen plug on the passenger side of the fuel tank for this purpose.  Use a straight  allen on a ratchet wrench, as I've broken the L-style of allen keys in my hand several times doing this same exact task.
***Disconnect the battery terminal before doing any of this.
kowalski
  • El\' Duder
Junk in my tank!!!
« Reply #5 on: April 17, 2008, 11:37:49 PM »
no, you don't have to pull the subframe, but you do have to pull out the driveshaft and the exhaust.
Sale:
Fore Sale Thread
Cobra Jet
Junk in my tank!!!
« Reply #6 on: April 18, 2008, 09:06:06 AM »
could you also remove the fuel pump assembly, drain the tank and once the interior of the tank has dried out thoroughly, use a shop vac to vacuum up all of the accumulated debris within the tank?  Seems that would be easier to do (if you can get the shop va hose in there enough to do it)...
- Phil
1994 Cobra coupe #0013
2011 Genesis Coupe
2011 Tucson GLS
kowalski
  • El\' Duder
Junk in my tank!!!
« Reply #7 on: April 18, 2008, 01:50:44 PM »
Quote from: Cobra Jet;47434
there is a fuel line that runs across the bottom of the tanks, because its 2 big reservoirs on either side of the driveshaft. you could just unbolt that and drain the tank from there.
Sale:
Fore Sale Thread
Ricer318ic
Junk in my tank!!!
« Reply #8 on: April 20, 2008, 04:07:19 PM »
Thanks alot guy you've helped out a bunch!:D
haledj
Junk in my tank!!!
« Reply #9 on: April 20, 2008, 04:47:17 PM »
dropping the tank is a huge pain in the ass.
