Author Topic: tach signal  (Read 6137 times)
jakeb
tach signal
« on: March 29, 2008, 06:44:45 AM »
Does anyone know how the tach signal works?  I have a m42 in my 2002 and trying to get the stock 2002 tach to work.  I connected it to the signal off the c101 plug but not getting anything.  So trying to figure out how I can get it to work or if I should go with an after market gauge.
I was able to really drive the car yesterday and it is fun fun fun.  The sound when you stomp on it is pretty insane.  I am running two straight trough magnaflows.  I will have to take a short video of it.
http://www.classicdaily.net - swapping this into that
http://www.blunttech.com - all your parts needs
christod
tach signal
« Reply #1 on: April 07, 2008, 06:35:08 PM »
Jake,
Ive got an e21 with an m42 swapped in and Ive run into similar problems.
Heres a post string I started some time ago that should shed some light on the situation.
http://forums.bimmerforums.com/forum/showthread.php?t=946870&highlight=pinouts
Hope it helps!
christod
tach signal
« Reply #2 on: April 07, 2008, 06:42:07 PM »
Also, if you want to spend a little money ($80 or so), this seems like the easiest and least finicky solution.
christod
tach signal
« Reply #3 on: April 07, 2008, 06:42:37 PM »
MLM
  • -Receive: 10
    • My M42 ITB Project
tach signal
« Reply #4 on: November 03, 2010, 05:56:38 PM »
Reviving a old thread sorry..
I am wiring in an aftermarket engine management system which outputs a 12v pulse for RPM. Will this work with a E36 guage cluster or does it require a 5v signal?
What have others done for RPM signals to standard guages when using a aftermarket system?
Any info on what the guage cluste expects as a signal much appreciated..
tach signal
« Reply #5 on: November 04, 2010, 08:40:08 AM »
It might be that the tach gets an AC signal...and the MSD linky above is down.  Here's a link for you (not sure how helpful it'll be): http://m3forum.net/m3forum/showthread.php?t=322373
If the car is still running, test that OBDII port pin 9 & see what it pulses at, AC or DC.
MLM
  • -Receive: 10
tach signal
« Reply #6 on: November 04, 2010, 02:52:41 PM »
CheersDave,
I should have done that before i yoinked out the the loom and ecu. Hindsight is a wonderful thing.
I know of others running my ecu in e30's and they connected it right up but i just want to tripple check before blowing somthing up. I have the option to adjust duty cycle etc on the ecu so may start concervative and work up..
tach signal
« Reply #7 on: November 04, 2010, 03:56:55 PM »
I'm pretty sure it's not a very powerful signal...I'd be willing to bet that 12vac and 5vac will both work.  YMMV  The caps in the cluster are cheap but not so much fun to replace.
