Author Topic: how do you remove your original radiator fan??  (Read 5088 times)
DRtothE
« on: March 28, 2008, 11:39:56 PM »
i need soe work space, and i didn't feel like digging around the engine bay to figure our how to remove the fan myself, so if you could help you be my best friend :D
« Reply #1 on: March 29, 2008, 03:22:37 PM »
How I do it:
Put a big crescent wrench on the the fan clutch nut with the handle pointing to about 1:00 o'clock looking from the front. Hit the end with a hammer in a direction of 10:00 o'clock to 4:00 o'clock. The threads are left handed, i.e., from the front turn the nut clockwise to loosen it. Instead of righty-tighty, it's righty-loosey!
stereomotional
« Reply #2 on: March 29, 2008, 08:52:34 PM »
yup, also it sometimes works to start spinning it with a wrench on the fan going slowly to the left, then bang it to the right really quick.   but the mallet method is easier :D
mkIV Jolf 1.8t (the DD)
BMWManiac
« Reply #3 on: June 26, 2008, 08:48:49 PM »
32mm wrench....then, use a long screw driver to keep the pulley from spinning....like everyone has said, turn the wrench clock wise from the front of the vehicle
2006 Interlagos Blue Z4M Coupe
Premium pack, navigation, heated seats
1997 Artic Silver M3
Built motor + SC62 + TRM tune
545rwhp/520rwtq
« Reply #4 on: June 28, 2008, 05:56:21 PM »
Quote from: BMWManiac;52093
Yup, the threads are "backwards."  I forget every time lol.  You can usually keep the pulley from moving just by holding the belt / squeezing the 2 sides together.
Getting it all back in is trickier than getting it out.  I have found that putting the fan on first, then wiggling the shroud into place afterward works pretty well.
BMWManiac
« Reply #5 on: June 29, 2008, 01:04:34 PM »
Be careful no to crack the pulley too!
545rwhp/520rwtq
DRtothE
« Reply #6 on: August 29, 2008, 05:33:32 AM »
thanks a heap fellas, can always count on my m42club brothers.
