Well, I did the headgasket on my new motor from a 95 car today, and cleaned it all up.
When I was putting the new headgasket in it, I sort of attempted to put it in backwards, and the two holes where the headbolts go got sort of disformed a bit, I ended up putting it in and it worked, as in it is in the right way now, but those holes were a bit moved up by a millimiter or two. The headgasket is flat and compressed, but I cant seem to forget that little mishap, and I just want to know if anyone had similar experiences. I would like to see if i am safe before i put this thing in.
Another thing is - I have no idea how to set up the timing on this thing. I found TDC on the crankshaft, and I have the cams parallel/perpendicular to the valvecover surface, but it seems to be off, cause there is no way to set it up in the same way as it is in the instruction manual - with the notches at the top and stuff.
Please let me know if anyone know the answer to either of these.
