Author Topic: crankshaft pin  (Read 2726 times)
stereomotional
crankshaft pin
« on: March 19, 2008, 06:46:14 PM »
is this pin tool really needed to remove the crank nut?  ive been trying to hold the crank while removing it and nothing works.  also btw...is it reverse threaded or regular?
http://www.bavauto.com/shop.asp
mkIV Jolf 1.8t (the DD)
stereomotional
crankshaft pin
« Reply #1 on: March 19, 2008, 06:47:52 PM »
i cant get the link to work...but its the bavauto crank pin holding tool.
crankshaft pin
« Reply #2 on: March 19, 2008, 07:06:19 PM »
There is a hole in the block and flywheel for locking the crankshaft. It's on the lower driver's side of the block. There is a special tool for it but you can use a long M8 bolt.
318is93
crankshaft pin
« Reply #3 on: March 19, 2008, 08:44:23 PM »
Look under your starter. You'll see a big hold or plug THEN look under that. You'll see a small hole. Thats the one you want.. Just FYI.
strypt
crankshaft pin
« Reply #4 on: March 20, 2008, 03:56:04 AM »
It's not really needed as there are other ways of holding the crank in place (ofc..) but it makes things SO much easier. Just remember to have the engine in TDC otherwise you'll have problems finding the hole in the flywheel ;)
The bolt has regular thread.
stereomotional
crankshaft pin
« Reply #5 on: March 20, 2008, 05:16:38 AM »
cool thanks.  tried to wedge a block of wood in the crank last night and someone even held the motor and stand and it was still coming off the ground...with a 3 foot breaker bar lol.
nomad
crankshaft pin
« Reply #6 on: March 20, 2008, 12:45:58 PM »
get a bolt, or even try the wheel placement rod that is in the trunk toolbox. I used a straight drift punch, basically a metal rod and I got the bolt off easy with a 25" breaker bar.
SoCal, 318is: IT RUNS AGAIN!
