Author Topic: Oil Leak in front of engine  (Read 7389 times)
Poooobaa
« on: March 17, 2008, 04:30:24 PM »
Hi - does anyone have some input as to the cause of this oil leak. It drips from the crank sensor onto the pan and then my garage floor. Cleaned everything and tried to follow to the source but it does not leak at idle, only after driving with higher revs. It does not appear to be coming from higher on the engine. Thanks in advance.:confused:
beegeezy
« Reply #1 on: March 17, 2008, 05:20:37 PM »
crank seal?
Poooobaa
oil leak
« Reply #2 on: March 17, 2008, 08:02:52 PM »
Thanks. The crank seal is new and there is no oil inside the pully wheel that covers it. It is something else.
« Reply #3 on: March 18, 2008, 05:00:38 AM »
post a pic...!i could be almost every seal in front of the engine..
Cobra Jet
« Reply #4 on: March 18, 2008, 07:49:09 AM »
There has to be (and always is) a "starting point" from where you could trace back the leak.
What I would do is this - get a can of Brakeleen (or generic brake parts cleaner) or spray on carb cleaner and spray down the entire front area of the engine, including timing cover, etc...  Start from the valve cover and go down.  Once you have thoroughly cleaned the entire area and either let the engine air dry or by drying it with a towel, then start the vehicle, let it idle for a bit (20 mins or so) and monitor that area of the engine.
If you do not see a leak with it idling, then take it for a spin around the block and recheck the front of the engine.
There are multiple areas of which the leak could be coming from, but in order to determine the origination, the entire front area of the engine should be 100% clean.  With a clean area, you *should* be able to find the starting point of the leak and then will be able to determine where the leak has originated from on the front of the engine.
- Phil
1994 Cobra coupe #0013
2011 Genesis Coupe
2011 Tucson GLS
Frankie
« Reply #5 on: March 18, 2008, 02:35:40 PM »
I have a same kind of leak coming from the front of the engine.
Poooobaa
Still leaks
« Reply #6 on: March 18, 2008, 10:00:51 PM »
Thanks for the input everyone. Right now I am really stumped so I will go over what I have done to correct this problem with no success.
Tore the engine down and replaced the valve cover gaskets, head gasket, profile gasket, timing cover upper gaskets, timing sensor o-ring, middle rubber gasket between the covers, thermostat o-ring and gasket, lower cover gaskets, water pump gasket, crank seal, oil filer housing o-ring and gasket, dip stick o-ring, lower pan gasket. Have not replaced the main pan gasket or the housing gasket for the oil galley panel between it and the engine block. Everything is 100% clean. I can only follow the leak about 2 inches up the crank sensor wire. Thats it.     :mad:
« Reply #7 on: March 19, 2008, 12:54:19 AM »
Possibly leaking at the cam gear sensor or between the upper and lower front covers and running down the lead to the crankshaft sensor.
Poooobaa
« Reply #8 on: March 19, 2008, 12:11:03 PM »
As stated above I replaced the o-ring on the cam sensor, plus I can see and feel that area of the engine. Not it. But thanks for the input.
e30matt
« Reply #9 on: April 08, 2008, 10:05:49 PM »
just because you have replaced all these seal doesn't mean thats not the problem
pifane
re
« Reply #10 on: April 17, 2008, 12:32:02 PM »
Hi!
Ive just changed all my gasket on my engine. After 100 KM of use, guess what : ANOTHER OIL LEAK!
So, my mechanical and me (ive no garage...) we just dissamble everything on the front and clean it (fan, fan clutch, radiator, plastic cover)..
My oil leak was on the side of the gasket cover....WITH NEW GASKET!!
So, we remove the new gasket, removing the A/C support, shorten bolt for more pression and fixe the cover with Permatex Gasket Builder and now, I have 800 KM running with that and its still ok!
Another question for you :
1- Ive changed my thermostat and my fan clutch and my engine is still overwarming......IT IS my water pump?
PIFANE.MONCHAR.COM
PartsCar
« Reply #11 on: April 17, 2008, 01:02:21 PM »
Quote from: pifane;47319
Hi!
You might need to bleed the cooling system first.
get your car to operating temp and open the hood and go near the radiator expansion cap. you will find a brass looking screw that goes into the top of the radiator.
get your screw driver and undo it a couple of turns and get back in the car and put the heat to full blast. go back to the engine bay and give the throttle a couple tugs and wait for all the bubbles to bleed out of the screw.
screw the bleeder screw back in.
then enjoy.
Cobra Jet
« Reply #12 on: April 17, 2008, 02:20:47 PM »
Hi!
So, even with replacing the original leaking gasket with a BRAND NEW gasket, you still had oil leak issues?  Just curious, what brand gasket was the new one that leaked?  What did you torque your timing cover bolts to?
Did you use the gasket sealer w/ the gasket, or did you remove the new gasket and just use the sealer by itself?
- Phil
2011 Genesis Coupe
2011 Tucson GLS
pifane
re
« Reply #13 on: April 17, 2008, 02:58:39 PM »
Quote from: Cobra Jet;47328
Ive buy kit selled on BMAPART?
Torque timing cover?
for the moment, I have no gasket at all on my timing chain cover. Just using "the right stuff" by Permatex..
So, my thermostat is changed, all the air have been drained by the screw near the radiator cap, brand new fan clutch and my engine is still not good cooled...
My car have 210 000 milles. The water pump? How I can be sure?
PIFANE.MONCHAR.COM
Cobra Jet
« Reply #14 on: April 18, 2008, 08:48:56 AM »
On this pic below - you are referring to the gasket(s) that would be behind parts # 1 (upper timing case cover) and 2 (lower timing case cover) - is this correct?
It would be gaskets # 15 & 16.
The reason I am asking is because my M42 was entirely rebuilt and the front timing cover gasket (which is also brand new) is also seeping oil...  The timing cover bolts are also torqued (tightened) to the correct spec per the available manuals.  The manuals did not state to use any type of sealant w/ these gaskets either...
I'm wondering if there is a manufacturing defect w/ these gaskets, because I don't see why brand new gaskets would be leaking after being installed 100% properly...
I think I will start a separate thread inquiring about this issue...
- Phil
2011 Genesis Coupe
2011 Tucson GLS
