Author Topic: 91 318is loud thumping on deceleration  (Read 3043 times)
nofear3544
« on: March 09, 2008, 09:12:21 AM »
Im getting a really loud thumping noise coming from what sounds like the front passenger side of my car. The noise appears when I do one of the following decelerate, brake, apply the clutch, turn right, or hit a large bump. The noise goes away when I give the car gas or drive at high speeds. I jacked up today and couldnt find anything noticeably wrong with the suspension. Please help
RED IS 91
« Reply #1 on: March 09, 2008, 12:54:31 PM »
maybe :
transmission mount?
guibo?
center bearing?
U joints?
motor mount?
nofear3544
« Reply #2 on: March 09, 2008, 01:20:43 PM »
ill check all of those could it possibly be a wheel bearing... i did replace the rear ones this past year.
RED IS 91
« Reply #3 on: March 09, 2008, 07:09:01 PM »
Quote from: nofear3544;44379
I've replaced my front bearings but I didn't have the symptoms your indicating.
Lift the front passenger side wheel off the ground .Grab the wheel at 12 and 6 oclock and try and move or shake it .If there is alot of play then your bearing may be shot.
My passenger side wheel bearing went at 191,000 miles but it would grind when I made a right hand turn.I replaced both .
sheepdog
  • Site Admin
« Reply #4 on: March 09, 2008, 10:33:32 PM »
I would bet guibo.
beegeezy
« Reply #5 on: March 10, 2008, 12:02:10 AM »
ball joints?
It\'s not paranoia if they really are out to get you.
nofear3544
« Reply #6 on: March 11, 2008, 12:48:36 PM »
i just had minake look at it cuz i dont have a lift.. anyway it was the driveshaft but it wasnt the guibo. it was the bracket that holds the rear of the shaft the rubber inside that bracket was bad and the shaft is hitting the metal.
nofear3544
« Reply #7 on: March 11, 2008, 12:51:12 PM »
the one defect of having a small car is that the driveshaft is hidden and requires alot to remove it.
sheepdog
  • Site Admin
« Reply #8 on: March 11, 2008, 08:50:39 PM »
Quote from: nofear3544;44572
Center Support Bearing
