Author Topic: OBDII fault code P1186 which O2 sensor?  (Read 3381 times)
bbojangles
« on: March 07, 2008, 08:23:38 AM »
it tells me this is Bank 1 Sensor 2. which of the 2 sensors is this?
This is on an 1996 318i sedan. check engine light is persistant.
From what I have gathered, it it is the pre-cat sensor, then it needs changing.  if it is the post cat sensor, then the likely thing is that the wires fell onto the pipe and melted.
Either way, I would like to know what sensor is generating the fault.
Looking under the car might help, but I would like to be armed with some info first..
thanks
1991 E30 M42
« Reply #1 on: March 07, 2008, 09:11:49 AM »
Sensor 2 from my experiences normally refers to the post cat o2 sensor.
ScreamerBeemer
« Reply #2 on: March 11, 2008, 09:19:09 AM »
Sensor 2 bank 1 indicates that bank one is on the same side as cylinder 1. Being a 4 cylinder that makes that easy. Sensor 2 is usually behind the cat as said before. O2 sensors are numbered by how close they are to the engine, the closer to the engine the lower the number.
