Author Topic: LSD Differential Options  (Read 2750 times)
Paul Strefling
« on: March 03, 2008, 06:43:53 PM »
I have a few questions that I was not able to find with the search.
Basically I would like to know if I can buy an LSD, say a 3.73 and put my 4.10 gears on it and install it in my small case. Which leads to the question, what is the difference between the small case diff and the large case diff?
I believe that is all for the time being. Thanks.
strypt
« Reply #1 on: March 04, 2008, 12:07:08 AM »
The difference is the size of the internals, 318is E30 has the small diff case with 168 mm ring gear and 325/M3 E30 has the larger one with 188 mm ring gear. The large diff with LSD is almost bullitproof while the smaller diff with LSD is pretty weak. The internals are not interchangeble.
Paul Strefling
« Reply #2 on: March 04, 2008, 07:27:33 AM »
That explains it very well, thank you.
Paul Strefling
« Reply #3 on: March 18, 2008, 06:48:07 AM »
What is weak about the the small case LSD?
