Author Topic: how to e36 turbo install step by step  (Read 28959 times)
ApocolypseAutoEngineering
« Reply #45 on: March 29, 2008, 05:07:10 AM »
It could be main engine relay.
E30 FOR LIFE!!!!
+mtxmatrixx
« Reply #46 on: March 29, 2008, 06:55:30 PM »
« Last Edit: April 03, 2008, 09:06:01 PM by +mtxmatrixx »
ose30
« Reply #47 on: March 31, 2008, 11:17:17 AM »
Looks like interesting project. Some notification i would like to add after building several Turbo charged engines.
That exhaust manifold with wastegate attached it and now with some extension pipeing is not the best possible design in performace point of view.
Oil circulation is not the way i would build it; at least i would route returnline to oilpan. You might run into difficulties if your pump is efficent.
Air/fuel ratio; how are you going to handle it? It's not wise to run "rich enough", you should get decent A/C ratio.
Original flapper AFM might be too small for your configuration.
Just few thoughs, any how good work ;)
+mtxmatrixx
« Reply #48 on: March 31, 2008, 12:40:55 PM »
« Last Edit: April 03, 2008, 09:01:52 PM by +mtxmatrixx »
« Reply #49 on: March 31, 2008, 12:47:35 PM »
Quote from: +mtxmatrixx;45762
i upgrade the wires to 8mm performance wires... EASY COSTUM job if you guys are intrested in how to do it let me know and ill post what parts to use .
I would really appreciate some details on this. My ignition wires are covered in cosmoline so they must be originals from 1991. LOL
+mtxmatrixx
« Reply #50 on: March 31, 2008, 02:53:13 PM »
« Last Edit: April 03, 2008, 09:03:08 PM by +mtxmatrixx »
« Reply #51 on: March 31, 2008, 03:44:12 PM »
Wow thanks a lot! I'll give a try and let you know how it goes.
cheers
95Compact
« Reply #52 on: March 31, 2008, 04:50:27 PM »
Quote from: +mtxmatrixx;45817
the return line is working fine i just test drove the car for 2 days allready . the turbo set to low to tap the oil pan as return point. NOW you mention the floper ....yes i know exacly what you mean and im thinking the same on that i dont know what route to go...(if i remove the floper what wud happend? ) is there a MAF convertion for my car?? if you know please gime me some imput.. ill post some video tonight running at 8 psi... it feels great but the A/F is jumping  lean for a split second in 3rd gear and goin back to rich... i havnt conect the lambada o2 yet but i figure that injectors #715 are 23% biger than stock and the fmu shud compensate for the rest.... now i dont know if the stupid flopers in the intake or in the maf are the cause of this...what is your take on this...?
If you remove the flapper from the AFM, the car won't run.  The ECU is calculating air mass from the calibrated flapper and the temp sensor (hanging down in the airflow). The TPS is likely only being used for accel enrichment, full-throttle enrichment, and overrun fuel cut (hard deceleration/coasting).
MAF Conversion:  http://bmw.e30tuner.com/articles_mafcon.php
The flapper in the intake system (the DISA valve) should be disconnected so that it no longer operates. It has an electric vacuum solenoid connected to the ECU which switches over at 4800 RPM (going up) and 4200 RPM (going down). Disconnect the vacuum line to the solenoid and that should stop it from operating. Alternatively, you could cut the wire that goes to PIN #18 in the engine harness.  That wire activates the DISA valve solenoid.
You really should have that WBo2 in there if you're driving at anything close to full throttle... I found my M42's stock NB sensor to be pretty far off.  The NB would also give false data when the engine sputters or misfires... and continued to give bad data for a second or two after the misfire.  If you're relying on the lambda sensor to make substantial mixture corrections (which it must be doing with the new injectors when NOT under boost) you should install the WB, program the output to simulate a NB and connect it to the ECU in place of the NB.  You'll get MUCH better mixture control when that is set up.
I don't know, but I doubt that the ECU is using the O2 data to make any larger than a 25% change in supplied fuel, no matter how far away from stoichiometric you get.  Seems like your FMU and larger injectors may be overpowering the maximum lambda correction MOST of the time.
Where is the spot where the engine goes lean? (RPM, estimated throttle position).
Can't wait to see a vid!  Congrats!
+mtxmatrixx
« Reply #53 on: April 01, 2008, 03:34:35 AM »
« Last Edit: April 03, 2008, 09:02:44 PM by +mtxmatrixx »
+mtxmatrixx
« Reply #54 on: April 01, 2008, 09:39:00 AM »
« Last Edit: April 03, 2008, 09:02:23 PM by +mtxmatrixx »
Turbozexcrxman
« Reply #55 on: April 01, 2008, 01:13:08 PM »
Those videos turned out great
the car feels really good under boost, def quicker than it used to be
ludiagsm
« Reply #56 on: April 01, 2008, 02:37:32 PM »
congratulations ,  you work quick and have results! I wish you luck further.:)
Turbozexcrxman
« Reply #57 on: April 02, 2008, 12:25:12 AM »
post my ripper vid on youtube.......
Shaheenem
« Reply #58 on: April 02, 2008, 08:45:24 AM »
+mtxmatrixx... Its looking really good so far... You moving really quickly... Wish i could do the same...
Congratulations!! Keep us updated!!
M44 Aggression
40mm Drop
Full custom Stainless steel exhaust
Viper branches
FI in the process
nuvolarossa
« Reply #59 on: April 05, 2008, 02:28:39 AM »
why all post are deleted?:eek:
I was out for work this week and now I see all deleted!
where are the videos?
thank you
