Author Topic: how to e36 turbo install step by step  (Read 28978 times)
sand_m4n
« Reply #15 on: March 09, 2008, 11:35:16 AM »
Awesome thread!
My E36 is about to get turbocharged at the start of this summer so this thread is really a big help. Hope you get every thing working right and make sure to add  more pretty pics :D
keep up the good work
Sand_man
+mtxmatrixx
« Reply #16 on: March 10, 2008, 08:28:55 PM »
« Last Edit: April 03, 2008, 09:07:48 PM by +mtxmatrixx »
318kid
« Reply #17 on: March 10, 2008, 10:02:10 PM »
I bet it's already answered, but what manifold are you using? Where did you find it. Thanks
bmw318is1994
« Reply #18 on: March 11, 2008, 01:29:56 AM »
Hey I've seen a guy take an M3 turbo manifold and he chopped the last 2 off and then welded a piece to cover the hole for a turbo manifold.  I found a couple fairly cheap looking around that I'm planning on doing for my E36.  Looks good man keep up the good work!  Thanks for posting this as well!
+mtxmatrixx
« Reply #19 on: March 11, 2008, 08:02:38 AM »
« Last Edit: April 03, 2008, 09:08:07 PM by +mtxmatrixx »
+mtxmatrixx
« Reply #20 on: March 12, 2008, 09:50:40 AM »
« Last Edit: April 03, 2008, 09:08:24 PM by +mtxmatrixx »
+mtxmatrixx
« Reply #21 on: March 13, 2008, 12:10:25 AM »
« Last Edit: April 03, 2008, 09:08:38 PM by +mtxmatrixx »
+mtxmatrixx
« Reply #22 on: March 14, 2008, 11:56:38 PM »
« Last Edit: April 03, 2008, 09:07:27 PM by +mtxmatrixx »
95Compact
« Reply #23 on: March 15, 2008, 08:32:10 AM »
I was thinking about making a new downpipe alltogether.  The 3" tubing is excessive and I think there may be problems with boost creep (in this low-pressure system) because the path through the turbo will have far less restriction than through the wastegate.
Also, there isn't adequate room under the car to run a full 3" exhaust all the way to the tail, especially around the rear sub-frame, so it will have to be reduced at some point along the way anyhow!  I'd also like to integrate the wastegate dump into the downpipe because the wastegate will probably be dumping from about 2500 RPM up, and it'll just be too damn loud to have a straight wastegate exhaust all the way from 3000-7000 at full throttle...
Are you going to use the stock cat?
Are you sure you need the scavenge pump on the oil return?  Looks like the bearings may be a couple inches above the oil line.  What if you rotated the center section about 25-30 degrees clockwise (as viewed from the rear).  I know the drain wouldn't be vertical, but it doesn't have to be exactly vertical.  Corky Bell recommends +/- 30 degrees max.
Keep up the good work!
+mtxmatrixx
« Reply #24 on: March 15, 2008, 11:54:34 AM »
« Last Edit: April 03, 2008, 09:03:39 PM by +mtxmatrixx »
+mtxmatrixx
« Reply #25 on: March 18, 2008, 09:47:06 PM »
« Last Edit: April 03, 2008, 09:06:44 PM by +mtxmatrixx »
« Reply #26 on: March 19, 2008, 08:31:45 AM »
Very cool project so far!  You are a definite DIY mastermind!
+mtxmatrixx
« Reply #27 on: March 19, 2008, 08:15:47 PM »
« Last Edit: April 03, 2008, 09:03:58 PM by +mtxmatrixx »
« Reply #28 on: March 19, 2008, 11:37:25 PM »
Does that oil pump just circulate oil between the turbo and an oil cooler in its own separate circuit or does it use crankcase oil? How how much electricity does it use?
I ran into the same problem with installing skinny injectors onto the E30 manifold. I guess the tip is a little different because it didn't have those pieces to reuse so I installed them with some 1/2 inch washers.
http://farm3.static.flickr.com/2159/2346412419_3b7eaa6550_b.jpg
Excellent project. Please keep updating. good luck
« Last Edit: March 19, 2008, 11:43:20 PM by tjts1 »
drrtybyl
« Reply #29 on: March 20, 2008, 12:56:38 PM »
Great project.  What turbo did you decide to go with?
