Author Topic: Noise in 2nd and 4th Gears  (Read 2480 times)
n2motorsports
« on: February 20, 2008, 08:10:18 PM »
here's a weird one:
when in 2nd or 4th gear there is a very noticable "whooshing" noise...sounds is best described between a metal scrapping noise and a rush of water being force through restricted metal pipes??  the noise is coming from the center console.
it happens at about 2k and gets louder as the rpm rises.  Anyone encounter this before?
velomech
    • http://www.addictivecycles.com
« Reply #1 on: February 20, 2008, 08:56:02 PM »
Get a second opinion, but that sounds like a bearing is going bad, what happens if your in fourth, and you pull back on the lever? Like just driving in fourth gear, holding it in gear hard with your hand? does the sound go away or get louder?
Cheers
Hodge
In the words of the Immortal Freddie Mercury..."Get on your bikes and RIDE!"
n2motorsports
« Reply #2 on: February 22, 2008, 11:39:31 AM »
Tried that, it made no difference.  The sound us usually under throttle, with or without load.  I'll swap out my tranny fluid with some redline stuff, see if that quiets it down.  Should I see some metallic shavings if a bearing is going bad?
Someone mentioned it could be the synchro, since it's only happening in 2nd and 4th.  Any ideas?
bmwe36m42
« Reply #3 on: March 10, 2008, 06:17:22 PM »
same thing happened in mine, just lost sync in 2nd gear and 4th is still noisey. sucks. dunno the fix for you but,it a rebuild for me.
