Where can the E30 M3 rear sway bar be purchased (if not available on the used market) and what is the cost of one?
Mark, you installed the M3 rear sway bar on your vert? What is your opinons as far as how the car handles after that upgrade as opposed to how it handled previously w/ the stock rear sway bar?
Since discussing the M3 rear sway bar, what was the size/diameter of the E30 M3 front sway bar - would it be a better set up to use both the front & rear sway bars from an E30 M3?
