The s42 engine was never used in a e30 only in e36 320i it replaced there the s14.the only similarity to the m42 is the bloc,chaincase and parts of the cylinderhead!everything else,like camcarriers,solid lifters,bore,stroke,crank,cams,valves etc. Is different. Surely it depends which evolutionstep you look at. So,dont think you can use parts of the s42 in your m42..
