Author Topic: e36 318ti won't start  (Read 2112 times)
whipsey
« on: February 16, 2008, 02:05:31 PM »
car was running fine parked up then won't start it turns over but just won't fire i've connected my diagnostics and found a fault code for the air flow sensor.  I have tested the afm and it seems fine what else could this be?
« Reply #1 on: February 16, 2008, 05:08:14 PM »
what about fuel pressure and spark?
nicknikolovski
« Reply #2 on: February 16, 2008, 06:58:16 PM »
See if you can hear the fuel pump priming, also make sure there is fuel in the car (don't rely on the gauge), check your coils and spark plugs, also is your battery fully charged?
demon510
« Reply #3 on: February 19, 2008, 12:06:36 PM »
The easiest thing to check is the boot for leaks that goes from the MAS to the throttle body.  If that is not the case, check for spark, then fuel.  If you have a clogged idle air valve you could have flooded the car and you will need to take off the valve clean it then do some weird BMW flooding sequence to get it started.
Pull a plug and smell, if it is strong you have flooded it or you can sometimes smell the exhaust when trying to start it, if it is strong then you have flooded it.
Do not start replacing parts, check the free stuff first.
