Author Topic: E30 M3 with M42  (Read 12253 times)
E30PQ
E30 M3 with M42
« on: February 15, 2008, 01:50:50 AM »
Will an M42 bolt up to an E30 M3 transmission?
I believe the E30 M3 uses the Getrag 265.
Does anyone have any experience with that transmission?
Thanks
Paul Q
haledj
E30 M3 with M42
« Reply #1 on: February 15, 2008, 02:37:11 AM »
I do not believe so, but I don't know.
However I do know for a fact that a e30 m3 with an m42 would be awesome, kinda
Vladi
    • http://www.bmwzone.ro/forum
E30 M3 with M42
« Reply #2 on: February 15, 2008, 03:13:56 AM »
Big chances it would work. Check the gearbox driveshaft to see if the m42 clutch disc fits. ;)
Philip_pl
E30 M3 with M42
« Reply #3 on: February 15, 2008, 06:06:29 AM »
Eu-spec E30 M3 had dog-leg gearbox, us-spec had H-pattern.
The ratios are as follows:
European-spec: 3.72 (1), 2.40 (2), 1.77 (3), 1.26 (4), 1.00 (5)
North American-spec: 3.83 (1), 2.20 (2), 1.40 (3), 1.00 (4), 0.81 (5)
Together with the 318is gearbox they all belong to the Getrag 265 "family".
I believe they are all interchangable. In the FIA homologation form for e30 318is, the eu-spec M3-gearbox is also mentioned as an option.
« Last Edit: February 15, 2008, 06:22:56 AM by Philip_pl »
strypt
E30 M3 with M42
« Reply #4 on: February 15, 2008, 07:35:53 AM »
No they are not interchangeble. Unfortunately :( because I'd love a close ratio gearbox in my "is".
S14 engine (M3 E30) uses the same bolt pattern for the transmission as the M10, M30, S38 etc... and the M42 has the same bolt pattern as M20, M50, S50 etc.
Edit: The M20 has the same bolt pattern but the engine actually has a different angle, so if anyone are planning on using such a gearbox, they'll need to modify the gearbox mounting and maybe even the linkage.
« Last Edit: February 15, 2008, 07:41:05 AM by strypt »
Philip_pl
E30 M3 with M42
« Reply #5 on: February 15, 2008, 08:41:00 AM »
That's interesting, since I know about people using 318is with M3 gearbox. I'll try to find out something...
E30PQ
E30 M3 with M42
« Reply #6 on: February 15, 2008, 10:39:13 AM »
Good feedback.
Phillp pl -- Let us know what you find out.
Philip_pl
E30 M3 with M42
« Reply #7 on: February 16, 2008, 08:45:29 AM »
OK, so I did some research and here is what I came up with:
318is has Getrag 240 with integrated bellhousing.
M3 has Getrag 265 Sport with separeted bellhousing.
In order to connect the M42 with M3-gearbox, you can swap the bellhousing from an e28 Getrag 265.
ispierrot
E30 M3 with M42
« Reply #8 on: February 17, 2008, 07:31:47 AM »
Hi
Have a box M3 on my 318is M42 and last week I made the installation of a box E36 318is on E30 M42 to a friend I will explain below.
Ownership of 318is M42 draw you like a little shorter this is the solution.
It is a box 316/318 i. TI is E36 = type box S5D 250G AJR
The reports boxes are:
318is E30
1 = 3.71 / 2 = 2.01 / 3 = 1.31 / 4 = 1.00 / 5 = 0.80
318/316 I. Is. E36
1 = 4.23 / 2 = 2.52 / 3 = 1.66 / 4 = 1.22 / 5 = 1.00
M3 E30
1 = 3.72 / 2 = 2.40 / 3 = 1.77 / 4 = 1.26 / 5 = 1.00
As you can see the report E36 is not far from a much cheaper M3.et
To make the calculation speed = http://www.flat4ever.com/?page=boite
The exhibits include
The turnover in the villo ref: 11 21 1720 310
Shooting 3 bushings for the transitional ring box E36 exit 12 mm bolts. E30 10mm. I will direct you to the dimensions. Long 30mm. ext 12mm. int. 10mm.
Extension of the stem command speeds 255mm. Take the E 36 it is larger in the box I also support vitese lever on a 318is
The box
Take the cylinder E36
Invert contactors reverse is not just for the socket
The old and new
We must extend the driveshaft playing on the setting, keep the support of box E30, the purging of the hydraulic clutch and go.
And the trick of the day, for the bolt is still ch ... Behind the starter, cut an old sheet, which is located between the engine and box, the part of the starter, making a half-moon weld nuts starter, establish the starter, the half moon slipping below par, setting the bolt easy in the positioning so that he is in front and put the bolt difficult that becomes easy, and tighten.
For info I have equipped with a lever Z 2.8 and a feast 318is a bridge 325IX report 3 / 91 V
« Last Edit: March 05, 2008, 03:50:24 PM by ispierrot »
ispierrot
E30 M3 with M42
« Reply #9 on: February 17, 2008, 12:06:30 PM »
Hi
These photographs of assembling the box M3 E30 on M42, he had to move lambda probe and change the bellhousing in a special to be found in Europe for the price of 650 euros in a preparer french
http://www.delagesport.com/index2.html
And put the driveshaft M 3.
« Last Edit: February 17, 2008, 12:10:33 PM by ispierrot »
haledj
E30 M3 with M42
« Reply #10 on: February 17, 2008, 03:29:14 PM »
do you have a picture of the bellhousing that mates to m42?
strypt
E30 M3 with M42
« Reply #11 on: February 18, 2008, 04:13:44 AM »
Quote from: Philip_pl;42876
Ok I maybe stand corrected ;) but in order for this to work the E28 gearbox must come from a 525e or 524td, and I'm fairly sure that none of those had a separate bellhousing.
Are you sure that the is you know about isn't in fact using the M3 gearbox from an E36? Because that one fits onto the engine perfect, I know because I have one in my is ;) (The pilot bearing needs to be changed if your M42 comes from a E30)
Philip_pl
E30 M3 with M42
« Reply #12 on: February 18, 2008, 08:29:04 AM »
Strypt, it seems that once again you are right and I am wrong :o
Really sorry for the mess.
It's confusing, since I am sure that in Poland there is at least one rally e30 318is using E30 M3 gearbox. At least that's what the owner claims, but I don't have any contact with him.
Moreover when you look in the FIA homologation form for e30 318is you find that the dog-leg e30 m3 gearbox is an option, so it seems there is some possiblity to make it work.
http://img256.imageshack.us/img256/3195/a540100003bo0.jpg
strypt
E30 M3 with M42
« Reply #13 on: February 18, 2008, 09:07:43 AM »
I think that he either has manufactured a special bellhousing himself (cut'n'weld) or he is in fact using the Getrag 245 'sport' gearbox. It's also a dogleg g-box and was an option on 323 E21 and has similar (same?) ratio as M3 E30 Getrag 265 but with the M20 bolt pattern. It's not as strong as the getrag 265 but if you have a standard M42 it's no problem ;) I also believe this is the gearbox mentioned in your FIA papers.
Philip_pl
E30 M3 with M42
« Reply #14 on: February 18, 2008, 09:36:58 AM »
Maybe you are right and he fabricated a bellhousing himself.
« Last Edit: February 18, 2008, 09:42:11 AM by Philip_pl »
