don't forget a larger fuel rail also helps...
If trying to get more fuel (or modifying fuel system) based on the entire engine modifications or dynamics, you should take into consideration:
1) higher psi fuel pump
2) adjustable fuel pressure regulator
3) larger fuel rail(s) on engine
4) larger chassis fuel lines from tank to engine fuel rail
5) larger injectors
6) fuel pressure gauge to monitor fuel pressure while driving
7) possible MAF (or AFM) meter upgrade
O2 sensor upgrade
9) tuning if the engine has been radically modified and is now a HP monster
Along w/ more fuel, then you should improve air intake & exhaust:
10) larger throttle body (if applicable)
11) some type of CAI system
12) aftermarket performance header(s)
13) aftermarket better breathing cat back exhaust w/ hi flow cat converters
Many people don't get their vehicle "tuned" after performing all sorts of mods, especially when improving the fuel system and adding forced induction... If throwing tons of aftermarket parts at the engine and you're just installing stuff w/ no tune, you're not going to optimize your combo and there is the possibility of damaging the engine.
