Author Topic: Oil on spark plugs! head gasket?  (Read 3455 times)
brianw84
« on: May 01, 2006, 10:04:48 AM »
Do i need to replace the head gasket? valve gasket? and how do i do this? i want to fix it myself and im not driving it until i fix it. btw i discoved the problem after finding out those bosch 4 plugs are bad, and mine were all crappy looking too!
Febi Guibo
  • m42 reporter
« Reply #1 on: May 01, 2006, 10:17:10 AM »
We have the E36 bentley here on PDF... it covers the M42 engine, including removing the timing cover, cylinder head so you can check stuff out and replace the gasket...
http://m42club.com/forums/showthread.php?t=182
Support M42club.com !!
brianw84
« Reply #2 on: May 01, 2006, 10:23:12 AM »
Thank You!!
brianw84
« Reply #3 on: May 01, 2006, 11:08:50 AM »
should i replace other gaskets too?
Febi Guibo
  • m42 reporter
« Reply #4 on: May 01, 2006, 11:12:42 AM »
yup... timing case + profile...
let's face it, this is a great time to replace the timing chain, timing chain rail, tensioner, thermostat and water pump too.
Ain't cars great!  :D
Wizard
« Reply #5 on: May 01, 2006, 03:44:32 PM »
If there is just oil laying on top of the plugs, it is your valve cover gasket and the spark plug seals. See:
http://www.realoem.com/bmw/showparts.do?model=AF93&mospid=47305&btnr=11_0264&hg=11&fg=15
and you can get an idea of what you need to change.
