Author Topic: 2 inch drop  (Read 10468 times)
TWM-M42
2 inch drop
« on: February 07, 2008, 09:59:17 PM »
anyone know where i can find a spring and shock combo with a 2 inch drop?
e30 4cyl
2 inch drop
« Reply #1 on: February 07, 2008, 10:43:21 PM »
haledj
2 inch drop
« Reply #2 on: February 07, 2008, 11:23:39 PM »
ireland engineering stage 3
jeff91-318is
2 inch drop
« Reply #3 on: February 22, 2008, 11:27:42 AM »
I think Bilstein makes one
2 inch drop
« Reply #4 on: February 22, 2008, 04:04:06 PM »
H&R cupkit wouldn't be a good choice IMO. They're very soft. IE3's w/ bilstein sports or koni would be a nice setup. Just be extra careful if you go this route or else you'll be replacing oilpans frequently.
1991 E30 M42
2 inch drop
« Reply #5 on: February 26, 2008, 06:52:14 PM »
BavAuto makes springs that will lower about 2 inches but they are soft which to some isn't a bad thing. I put a set of them on my dad's car and he doesn't have any complaints.
DZick
2 inch drop
« Reply #6 on: March 01, 2008, 03:52:24 PM »
Coilovers are the only way to get real Low
stereomotional
2 inch drop
« Reply #7 on: April 06, 2008, 01:25:59 PM »
Quote from: Eurospec;43348
:D
mkIV Jolf 1.8t (the DD)
DaveM-sport
2 inch drop
« Reply #8 on: April 07, 2008, 07:49:17 AM »
Anyone know where I could get that springs would give a 2" drop on the front and maybe 1.3" on the back.
Will be running Bilstein B8 shocks and M3 type arbs.
Don't want it too hard I suppose since roads can be kinda bumpy here but still want it to be very satisfying in the turns.
I had a Cup kit in it, but toook it out straight away again as it was too low on the back and way too soft/bouncy
2 inch drop
« Reply #9 on: April 08, 2008, 04:33:31 AM »
Quote from: stereomotional;46259
:D
oh thats cool, is that for ventilation?? how much hp did you gain?
RedHoodRidah
2 inch drop
« Reply #10 on: April 08, 2008, 09:40:53 AM »
Quote from: DZick;43942
You know it!!
Oh my car is so Brilliant with no Rot...
I <3 my M Forty Two & E Thirty
2 inch drop
« Reply #11 on: April 08, 2008, 03:37:38 PM »
eibach springs and bilstein shocks.. thats my combo for summer!! 3-4 cm lower than stock...
sha1234
2 inch drop
« Reply #12 on: April 09, 2008, 11:54:21 AM »
I've been looking into some KW setup's... IE 60/40 (60mm front 40mm rear) but thats just cause i want that look, they have many other setups with different lowering heights
2 inch drop
« Reply #13 on: April 09, 2008, 04:57:55 PM »
some kw coilovers? or some springs and dampers? if yes... tell me how much you pay there in canada... because i have some connection to the kw headquarter here in switzerland.. ;-) perhaps i can arrange sth... incl. shipping in canoe.. hihihi...
quinn11m20
2 inch drop
« Reply #14 on: April 09, 2008, 06:49:14 PM »
Is your car a daily driver? If it is I would not go more than an Inch and a half. Your car will ride so horribly. If you do, put strut tower braces on the front and rear watch the profile of you tires, thinner, equals hard ride, thicker, equals softer ride. Work with the math on this one, you still want travel with the shocks. Coil overs would be the most optimum way to enjoy the ride and have superb handling.
