Author Topic: E36 M42 into E30  (Read 3315 times)
colin86325
E36 M42 into E30
« on: February 06, 2008, 09:42:56 AM »
I'm getting an E36 engine to drop into my E30.
Is it worth it to grab the ECU so I'll have knock sensor control?
Or do you recommend converting the E36 motor to use the E30 ECU?
Thanks,
Colin
Vladi
    • http://www.bmwzone.ro/forum
E36 M42 into E30
« Reply #1 on: February 06, 2008, 01:11:57 PM »
First of all, the e30 ecu won't work on the e36 engine without the e30 harness.
Knock sensors are good for you. ;)
haledj
E36 M42 into E30
« Reply #2 on: February 06, 2008, 02:32:52 PM »
I would use the e36 harness and ECU, one thing you might run into as a problem is the e36 coils are all pugged in with one connector as the e30 coils are plugged in individually.  Not that big of an issue but something of which you should be aware.
HaNasich
  • OO==00==OO
    • http://www.bangbros.com
E36 M42 into E30
« Reply #3 on: February 07, 2008, 07:03:09 AM »
perform search - u might like it :)
WowMom
BTRA!
