Author Topic: Driver's side low-beam  (Read 2665 times)
John W
« on: February 05, 2008, 08:37:25 PM »
My driver's side headlight is out. Low-beam only. Replaced the headlight (standard sealed beam) and replaced the #13 and #14 fuses. Still no light. What do I check next?
Thanks.
1991 BMW 318is SOLD :(
1976 BMW 2002 m20
2005 Ford Focus ZX-3
« Reply #1 on: February 06, 2008, 02:26:03 AM »
Make sure you have a good ground to that bulb.
« Reply #2 on: February 06, 2008, 10:22:47 AM »
and check the connectors/wires for damage
John W
« Reply #3 on: February 20, 2008, 07:21:40 PM »
Thank you, both, for your help. After replacing the headlight, the fuse and cleaning the grounds, I discovered I used the wrong headlight. Yep, I'm an idiot. ... ;)
1976 BMW 2002 m20
