DISCUSSION
Suspension
rear rubber mounting and wheel bearing replacement
Pages:
Topic: rear rubber mounting and wheel bearing replacement (Read 9148 times)
Hero Member
-Receive: 1
Reply #15 on:
April 07, 2008, 10:15:15 AM »
first the wheel bearings...
remove the brakecaliper, the brakediscs, the damper and the output shaft..
Hero Member
-Receive: 1
Reply #16 on:
April 07, 2008, 10:16:15 AM »
then the luxury version...
the easy way to remove the hub...
Hero Member
-Receive: 1
Reply #17 on:
April 07, 2008, 10:17:01 AM »
Hero Member
-Receive: 1
Reply #18 on:
April 07, 2008, 10:18:18 AM »
with this tool you can remove the bearing with pulling it out ... the same tool is used to push in the new bearing and the hub..
Hero Member
-Receive: 1
Reply #19 on:
April 07, 2008, 10:19:09 AM »
next time more...
enildeR
lol ur face
Reply #20 on:
April 07, 2008, 05:04:19 PM »
thanks for the pics.
Hero Member
-Receive: 1
Reply #21 on:
April 13, 2008, 11:50:44 AM »
front hub change...
Hero Member
-Receive: 1
Reply #22 on:
April 13, 2008, 11:53:22 AM »
the hub-set...
Hero Member
-Receive: 1
Reply #23 on:
April 13, 2008, 11:55:43 AM »
because the stupid quy on the phone where we order the parts dont know the different between ABS and NO-ABS hub...i have to modify the hub before assembly..
removing the ABS ring...
Hero Member
-Receive: 1
Reply #24 on:
April 13, 2008, 11:57:25 AM »
then remove the front-wheels..
then remove the nut which holds the hub...
Hero Member
-Receive: 1
Reply #25 on:
April 13, 2008, 11:58:42 AM »
i removed all the hubs with an adapter and a slidehammer..
Hero Member
-Receive: 1
Reply #26 on:
April 13, 2008, 12:00:30 PM »
after that the new hub.. some shiny blingbling..
thighten the nut and fix it ..
Hero Member
-Receive: 1
Reply #27 on:
April 13, 2008, 12:01:47 PM »
one rear wheelbearing, two fronthubs in 90min..!!pretty fast.. hehehe... ;-)
Hero Member
-Receive: 1
Reply #28 on:
April 16, 2008, 12:14:46 PM »
hui... i am driving around like in a rolls royce.. without any noises from the wheels..! very comfortable..!! cool thing... :cool:
Legendary
Reply #29 on:
April 16, 2008, 05:28:52 PM »
I did mine not to long ago. The fronts are really easy, especially if you did the rears first. I actually broke 2 slide hammers trying to get the right rear out. It had gotten so hot that it welded itself into the trailing arm. Took 12 hours total (not consecutive lol) hours to get the one out. The other only took about an hour because the brakes and everything were already off. Too bad I'm underage, beer must be niiiiiice
Pages:
DISCUSSION
Suspension
