Author Topic: Lift Throttle Clunking from Rear  (Read 2782 times)
Petebee
« on: February 02, 2008, 06:20:25 PM »
I have a pronounced clunk that occurs from what sounds like the rear of the car whenever I abruptly lift the throttle in a lower gear and get the car to jerk (kinda like a bad driver). I also noticed that if I engage the clutch immediately after hearing this and quickly move the shifter back and forth from first to second gear it sounds and feels a bit clunky, too. After moving the shifter back and forth about four times it stops making the noise/feeling and shifts smoothly.
Any ideas? I thought this may be a CV axle, and I replaced the passenger's side due to axial play in the shaft (approx. 1/8 - 3/16 inch of play if you pushed the axle back and forth from the diff to the rear hub). This amount of play seemed to be excessive. The driver's side has a slight amount, but not nearly like the passenger's did. I replaced the worn axle without drama.
My guesses (I am new to these cars) are:
- Worn rear subframe mounts (yuck)
- Something wrong with the driveshaft (yuck)
- Something wrong with the differential (yuck)
- Worn bushings in the trailing arms, diff and/or upper shock mount (not bad)
What do the gurus here think? I am kind of bummed as I know that I need to spend at least $500 to fix the worn timing components and I'd like to replace the OE suspension so that I can autocross this car. Sigh...
Car is 318i with factory LSD
mdiddy
« Reply #1 on: February 02, 2008, 08:04:37 PM »
could be bad diff mount bushing..or in my case, gear lash in the diff. the open diff i had before did the same thing..
Petebee
« Reply #2 on: February 02, 2008, 08:12:10 PM »
Quote from: mdiddy;42114
Hey are you around tomorrow (Sunday)? Maybe you can listen/feel for yourself.
mdiddy
« Reply #3 on: February 02, 2008, 08:21:26 PM »
yeah, thats fine. i'll be around all day. give me a call
Petebee
« Reply #4 on: February 02, 2008, 08:46:49 PM »
Will do. Thx.
