Author Topic: Why is this stalling?  (Read 3092 times)
Jak318
« on: January 31, 2008, 07:04:28 PM »
If I shut the car off after its warmed up and then wait a few minutes then start it up it does this. http://www.youtube.com/watch?v=ExqLcHyosB4
In the video i'm trying to hold RPMs and you can see it falling until I have to rev it up again. This goes on for about 30 seconds then it runs fine. When its about 10 seconds in I get a check engine light. With my code reader I get the Lambda (emissions) Control code.
Nevermind the temp gauge, It sticks sometimes.
Parts replaced so far, O2 sensor, coil on plug, and vacuum lines.
Ideas?
DZick
« Reply #1 on: January 31, 2008, 08:56:39 PM »
Do you have a CAI or open element filter? if so put your stock air box back on, i had the same problem you most likley arent getting enough vacumm pressure
Jak318
« Reply #2 on: February 01, 2008, 10:08:33 PM »
Yea, I do have a CIA but it came with the car. I never got the factory box. :mad:
Voluted
« Reply #3 on: February 28, 2008, 09:34:55 AM »
I had the exact same problem and it vanished after i cleaned out my Idle Control Valve with throttle body cleaner. Take a look at this writeup:
http://www.esatclear.ie/~bpurcell/318isfaults.html#idlecontrolvalve
I was able to take it off and put it back on without taking the intake manifold off  but however you chose to remove it and put it back in is up to you :o.
Try cleaning it before replacing it as he suggests as it is an expensive part (~170 from the dealer).
Jak318
« Reply #4 on: February 29, 2008, 08:01:45 PM »
I might just try that. I got my 4 pintle injectors so ill be down there when I install them.
