Author Topic: motor mounts  (Read 3310 times)
pwforprez
motor mounts
« on: January 29, 2008, 03:01:09 PM »
i was reading around and was told e28 motor mounts fit. is this true? or is there any bad that can happen when i use them
m10m42
motor mounts
« Reply #1 on: January 30, 2008, 01:24:27 PM »
I have read that e28 m5 engine mounts are ideal for swaps....
johna
    • My BMW 3 Series Website
motor mounts
« Reply #2 on: January 30, 2008, 03:00:34 PM »
Quote from http://www.motortraders.net/groups/group.asp?group=1&menu=1&article=1
Quote
You can fit E28 535i rubber engine mounts (P/N 11811132793) in place of the M42's hydraulic mounts. They will be a lot rougher and noisier at idle but not much above 1,000rpm. The benefit will be much better response from the engine from the standing start and on the move as there is less give in the engine, keeping the driveline straight. Not recommended for those who like a quiet comfortable ride. To fit you will need to remove the alignment tabs from each E28 mount and you will need to add a spacer (10mm ID x 2mm) on top of the thin factory washer.
Some quotes from people who have fitted these mounts:
"They will need a bit of trimming before they'll fit in properly. The car does vibrate more but it's only noticable at idle... and actually when it's cold. Once the car is warm you won't notice. I did notice a significant improvement as well! Better throttle response! If you like a soft ride or less vibrations throughout the cabin then I'd pass."
Wizard
motor mounts
« Reply #3 on: January 30, 2008, 07:55:23 PM »
pwforprez
motor mounts
« Reply #4 on: January 31, 2008, 03:29:23 PM »
thank you very much. i ordered the green ones from pelican but i got them they were black.. labled with the same part number.. i sure hope they will work
strad
motor mounts
« Reply #5 on: January 31, 2008, 03:41:39 PM »
^^^ they did change the color on those.  Forget who told me that, but someone on one of these forums.
pwforprez
motor mounts
« Reply #6 on: January 31, 2008, 03:47:36 PM »
wel the part number is the same as the green so im guessing its good.
