OSRAM for dummies
Author Topic: OSRAM for dummies  (Read 8279 times)
shellback
OSRAM for dummies
« on: April 30, 2006, 12:42:32 PM »
Hi everyone,
Ok, quick bio:
1991 318i :)  :)  :)
1997 M3/4/5 :D
My 318 has smilleys and H1 OSRAM's in the low beams. Part number 64150SVS.
I just picked up a set of euro ellipsoid lights for the M3, and noticed the bulbs are the same (H1 OSRAM)
Here are my questions:
1) Where can I purchase these same OSRAM's?
2) Are these H1's only for low-beams? Or do OSRAM H1's also go in the high beams?
3) I assume the OSRAM's are not DOT approved, correct?
Thanks,
Chris
OSRAM for dummies
« Reply #1 on: April 30, 2006, 12:47:35 PM »
OSRAM is just a brand, and yes euro ellips have H1's for lows and highs.  You can try to get some off ebay or something.
OSRAM for dummies
« Reply #2 on: April 30, 2006, 06:06:58 PM »
I got my Osram bulbs from http://www.powerbulbs.co.uk  They ship to the US.
Febi Guibo
  • m42 reporter
OSRAM for dummies
« Reply #3 on: April 30, 2006, 06:38:01 PM »
hey... a long time ago, I used to sell lightbulbs (non automotive, sadly) ...but, generally speaking, it's the fixture (the projector, reflector, lense, wiring assembly + OEM bulb) that's dot approved.
so, yer pretty much all set if you stick with h1 bulbs... in your m3;
the ellipsoid fixtures in the E30 are E1 approved (european) but not DOT, even with the same h1 bulbs
anyway... you want osram silverstar H1s...
Support M42club.com !!
shellback
OSRAM for dummies
« Reply #4 on: May 01, 2006, 10:25:11 AM »
Awesome - great info from everyone.
Thanks,
Chris
lordschleife
OSRAM for dummies
« Reply #5 on: May 02, 2006, 07:37:47 PM »
Quote from: bmwman91
From what I've read in the UK Osram Silver Star are the bulbs of choice for the best illumination, or if you want a whiter light though not quite as bright then go for Philips Blue Vision (which is what I have at the mo)
Cheers,
Robin
nickmpower
OSRAM for dummies
« Reply #6 on: May 02, 2006, 08:58:26 PM »
so these are the best for ellips? and get some for the highs and lows?(4)
sumyungguy
  • b.wood
    • http://www.shutterflick.com
OSRAM for dummies
« Reply #7 on: March 13, 2007, 11:35:05 PM »
I know this thread is ancient, and Im not sure if its been coverd..
Sylvania Silverstars are Osram's..
 I just picked up some Sylvania Silverstar H1's and the bulb's say "Osram Germany" on them. Just thought Id let it be known cause I ran across this thread when I was looking for ellipsoid data..
brad™
jpod999
OSRAM for dummies
« Reply #8 on: March 14, 2007, 07:54:26 PM »
How much for the 4 H1's?
sumyungguy
  • b.wood
OSRAM for dummies
« Reply #9 on: March 14, 2007, 10:52:29 PM »
their $19.99 a pop.. Im only doing my head lights, I rarely use my brights so why spend the extra $$..
brad™
jpod999
OSRAM for dummies
« Reply #10 on: March 14, 2007, 10:56:45 PM »
Quote from: sumyungguy;21332
Sweet, I am going to try and buy all the connectors I need this weekend and then hopefully I will have money left over for the lights.
sumyungguy
  • b.wood
OSRAM for dummies
« Reply #11 on: March 14, 2007, 11:08:15 PM »
Quote from: jpod999;21333
Sweet you got some Ellip's??
brad™
Alpine003
OSRAM for dummies
« Reply #12 on: March 15, 2007, 08:46:16 AM »
Quote from: sumyungguy;21267
Yes and no. The European Silverstars will have the part # above indicated with a suffix of "SVS". If it doesn't have this, then they are not Euro Silverstars. Walmart sells Osrams for $5 each for the H1 bulb. They don't have the "SVS" indicator. I have bought these and measured them side by side to my Euro Silverstars and definitely is different. Just remember there is US Silverstars and Euro Silverstars which are vastly different.
I got my Euro Silverstars for alittle bit under $30 for the pair.
« Last Edit: March 15, 2007, 08:48:48 AM by Alpine003 »
turbo_negro69
OSRAM for dummies
« Reply #13 on: March 15, 2007, 09:04:01 PM »
Quote from: Alpine003;21349
aren't the euro silverstar's clear and the US silverstar's blue?
91-318i SOLD : (
91-318is for sale
95-740i DD
84-Monte carlo SS Under construction
90-T-bird Supercoupe DD
Alpine003
OSRAM for dummies
« Reply #14 on: March 16, 2007, 08:46:45 AM »
Quote from: turbo_negro69;21404
Yes, that is correct but I was just trying to point out the difference between the US Osram and the Euro Osram that is often marketed over there as "Silverstars" since they both are clear and say Osram on them with the same part # except one having the "SVS" suffix designation. The "SVS" are the ones that have the brighter (and whiter) output and better filament technology over the regular US Osrams.
