Author Topic: a swiss 318is racecar  (Read 28507 times)
« Reply #15 on: January 26, 2008, 07:45:10 PM »
I would also try to build the car to be easily convertible to run in as many classes as possible.  I don't really know what series you could shoot for in Switzerland but the proposed body modifications would put you in a class over here where you would probably be running against all out tube frame cars here.
« Reply #16 on: January 27, 2008, 06:21:10 AM »
i am planning to use the car for hillclimbing...!! and to make a few rounds on the "Nordschleife". i have to talk with the guy who is modifying my cylinder head. they build some very fast m3e30 for race series in germany. i need a reglement and then i can see whats allowed or not.
but the major problem we have in switzerland is that we dont have any racecircuit!!!allowed are slaloms, hillclimbing... thats it!! due to a heavy crash in le-mans back in the 50s-60s where a couple of people died, the government stopped racing in switzerland!
« Reply #17 on: January 27, 2008, 06:29:46 AM »
fasten your seatbelts....!!!!
hillclimbing in switzerland looks like that:
« Reply #18 on: January 27, 2008, 10:51:15 AM »
Quote from: D. Clay;41689
Put the driver as far back and to the right side as you can. Extend the pedals and steering column to compensate. Make a dash that covers it all up. Put the battery in right rear and as much stuff as you can on the right side of the car. Make everything on the left side such as steering shafts, pedals, gauges, etc. as light as possible. Try for 52% rear weight and as close to 50/50 side weight as you can get. Then use ballast if needed where you think it will do the most good. Move the engine and trans to the rear and to the right as in post 7 above.  Driveshaft, and differential to the right a few inches. Use corresponding longer and shorter axles and modify the suspension crossmember accordingly. This will give even more room to get the driver toward the center of the car. No limits? You asked.
wow!!!! YEARS of work!!!! i was thinking pretty much the same... i think i have to cut the firewall and the transmission tunnel, then i have to relocate(put upwards) the rear mounting points for the rear crossmember.. and the same in the front. so i can lower the car. they do the same with the wtcc cars. the suspension stays on the same place only the body is lowered.
« Reply #19 on: January 27, 2008, 11:15:47 AM »
pics of an older opel astra
the seat is near the rear axle
puuu...! what a sick idea to build an extreme racecar! ;-)
« Reply #20 on: January 27, 2008, 06:55:08 PM »
Quote from: swiss318is;41781
you're so right! makes me want to find an old e21 and build a race car too... maybe (probably) as a long term project
here's a link that might interest you
http://www.davidmcintyre.org/
« Reply #21 on: January 28, 2008, 02:52:54 AM »
yep, i found that site long time ago!but thanks anyway!cool things there
« Reply #22 on: February 04, 2008, 02:57:17 PM »
does anybody have some fiberglass or carbon doors?hood?lid?fenders? or other stuff on his car? if so, what brands do you have?
has somebody a rollcage welded in his 318is? pics?
what steel quality is used to build a rollcage?
« Last Edit: February 04, 2008, 03:32:58 PM by swiss318is »
« Reply #23 on: February 04, 2008, 08:23:53 PM »
here you will find some carbon fiber parts, at least the hood for e30, the rest is for 2002tii i think, shipping might be a little too much though
http://bmw2002.com/
Philip_pl
« Reply #24 on: February 05, 2008, 12:55:19 PM »
Quote from: swiss318is;42196
The blue one is mine, the red one belongs to my friend:
I can take some more pictures of the blue one if you want.
Both the rollcages are made according to Appendix J of FIA regulations, which means the material is a cold drawn, seamless, unalloyed carbon steel (max. 0,3% of carbon)
« Last Edit: February 05, 2008, 01:04:41 PM by Philip_pl »
« Reply #25 on: February 05, 2008, 01:08:01 PM »
YES!!!thats what i am talking about!next thing will be to buy some kilometers of steel!! how did you bend the tubes??popeye?
hows the trunk looking? what about the sunroof? do you replace it with something?
by the way, good job!! cool pics! thanks!
« Last Edit: February 05, 2008, 01:12:55 PM by swiss318is »
« Reply #26 on: February 05, 2008, 01:16:20 PM »
what about the weight of the rollcage?? +/-?
Philip_pl
« Reply #27 on: February 05, 2008, 01:35:22 PM »
No idea how the pipes have been bended. I've had the rollcage done by a workshop.
My sunroof has been cut out and welded.
My friend did it different way. He had cut out part of a roof from a non-sunroof E30 and glued it on the top with car-window glue. It stick properly.
The trunk:
http://img100.imageshack.us/img100/7571/p3110116xp7.jpg
http://img255.imageshack.us/img255/6392/p3110118st2.jpg
http://img255.imageshack.us/img255/5294/p3110121ie1.jpg
Some more pictures of the cage:
http://img255.imageshack.us/img255/808/p3110139yb6.jpg
http://img255.imageshack.us/img255/5606/p3110138kt7.jpg
Philip_pl
« Reply #28 on: February 05, 2008, 01:43:53 PM »
Weight is ~50kg I suppose
« Reply #29 on: February 05, 2008, 01:55:25 PM »
nice, nice!! i am thinking about to make a carbon air-inlet on the roof instead of the sunroof! to save some weight! go to "s42 race engine" i took this pics last week! i have a lot of ideas for a rollcage, but i have never seen one in an 318is e30.
