Author Topic: Small to Medium Case Differential Swap - Definitive answer?  (Read 4814 times)
phredphish
« on: January 23, 2008, 07:58:33 PM »
I've searched the posts and can't seem to find a definitive answer. Does a e30 medium case differential bolt in (without modification) to my 1991 m42 318i?
I don't care about ratios or anything else, there is plenty of information on that elsewhere, all I want to know is the answer to my question above.
Thanks,
Andrew
« Reply #1 on: January 24, 2008, 04:00:32 PM »
yes
tim_s
« Reply #2 on: January 24, 2008, 04:14:31 PM »
mine needed the prop to be shortened on the collar, but yes did fit without any other modification.
2.1 200bhp, 175ft/lbs 318is
E46 330ci daily
gjuuu
« Reply #3 on: January 26, 2008, 02:28:47 AM »
I found that I had to slot the top two holes in the subframe by approx 5mm.
You can sort of see the difference in this photo - I tried to highlight the difference the best I could.
This could be for numerous reasons - my car is a 1991 and the diff is from a really early e30.
But having said that it was no big deal - just frustrating as the bolts just wouldn't line up no matter what I tried :(
romkasponka
« Reply #4 on: January 26, 2008, 03:23:55 AM »
The same was with mine swap. But as I know my dif was from E28 and just rear cover was replaced.. I think housing is the same like yours..
E30 318is M42
E36 318is M44
twinpop171
« Reply #5 on: January 26, 2008, 05:19:59 AM »
Yes.
I recently did this swap.  I also swapped the half shafts from the donor car.  They are a little shorter than the small case shafts iirc.  Mine bolted right in but it was a bit of a PITA to get the bolts started.
Good luck, Dan.
Brillantrot 1991 318is
Wizard
« Reply #6 on: January 27, 2008, 07:40:56 AM »
Also did this swap last summer-4.10 small case to 4.10 LSD medium case....Nothing else was swapped out and fit perfect.
Dan
DZick
« Reply #7 on: January 31, 2008, 08:38:43 PM »
Quote from: gjuuu;41724
Same
