Author Topic: Late M44 in an E30.  (Read 13077 times)
Royalratch
Late M44 in an E30.
« Reply #15 on: May 25, 2008, 03:53:34 PM »
You can,it's fine - I have.
strypt
Late M44 in an E30.
« Reply #16 on: May 26, 2008, 02:11:59 AM »
I have too, no problem.
KyleTaylor
Late M44 in an E30.
« Reply #17 on: July 29, 2008, 03:15:39 PM »
Quote from: strypt;50058
To reserect a not so old thread...
Wasted spark is no big deal, but if it goes into that mode then the fuel injection will also go into paired firing...  This will hurt fuel economy.
Can anyone take some detailed pictures of the cam gear?  I would imagine they will interchange as the engines are so similar in design.
strypt
Late M44 in an E30.
« Reply #18 on: July 30, 2008, 05:29:31 AM »
Quote from: KyleTaylor;54003
Fuel injectors are always fired in pair on the M42, just look at the wiring diagram for the engine harness if you dont believe me.
KyleTaylor
Late M44 in an E30.
« Reply #19 on: July 30, 2008, 09:29:55 PM »
I will take your word for it... man, if they had used fully sequential injection I would get 40 mpg instead of 33!
Dunno if it would make that large of a difference... I guess this kills the cam sensor issue, wasted spark is fine if the injection already is paired.  Sweet.
mkodama
Late M44 in an E30.
« Reply #20 on: August 02, 2008, 11:21:18 PM »
Quote from: KyleTaylor;54072
Here's some random facts:
The improvement of sequential injection on mileage depends on driving conditions.  The improvement is mostly seen at idle and very low RPMs.  Only until around 2300 RPM can most engines inject fuel before part of the fuel is injected on a closed intake valve.  But that isn't a bad thing as you might think, since this cools the valve as well as speeds up the vaporization of the fuel.
Sequential ignition on the other hand(if I remember correctly!), doesn't have any effect on mileage or power really.  It's just like wasted spark, but without anything being wasted.  And since the coils are being fired less often there is less wear/longer life for ignition components and since they have more time between firings, the coils can reach higher RPMs and be smaller without overheating.
mkodama
Late M44 in an E30.
« Reply #21 on: August 02, 2008, 11:26:18 PM »
Quote from: strypt;41300
The crank sensor work with M42 ecu but the cam sensor doesn't. M44 uses a hall type sensor and M42 uses VR.
So the crank and cam sensors on the M42 are both VR sensors?  (I'm preparing for a megasquirt install)
strypt
Late M44 in an E30.
« Reply #22 on: August 03, 2008, 11:48:20 AM »
Quote from: mkodama;54229
Yes, I'm running Autronic SM4 with the original sensors/triggers.
mkodama
Late M44 in an E30.
« Reply #23 on: August 03, 2008, 01:18:33 PM »
Quote from: strypt;54253
Thanks strypt! ;)
nuvolarossa
Late M44 in an E30.
« Reply #24 on: August 19, 2008, 05:23:08 AM »
So the M44 crank sensor too is VR, right?
thinking standalone here:rolleyes:
strypt
Late M44 in an E30.
« Reply #25 on: August 19, 2008, 07:55:25 AM »
Quote from: nuvolarossa;55146
Yes but the cam sensor is hall-type on the M44.
nuvolarossa
Late M44 in an E30.
« Reply #26 on: August 19, 2008, 10:12:44 AM »
sure for the cam sensor, that's wrote too in ETM manual!
thank you
