Author Topic: Engine not well  (Read 2583 times)
318isle
Engine not well
« on: April 29, 2006, 11:36:16 PM »
Hello M42 engine Gurus!
Here is the problem I'm having with my car.
When the engine is cold, it misses really bad and even has a little backfire!
Then when it get all warm a fuzzy, it purrs like a kitty!
I checked my wires and spark plugs, I did find some oil in #1 & 2 plug, but the plug itself was clean.
Could this be the start of a bad head gasket?
If so, I'll really need to remove my head now.
Any advice pertaining to this problem is greatly appreciated.
Mahalo!
318isle
Engine not well
« Reply #1 on: April 30, 2006, 01:50:41 PM »
Okay since no anwers from the Gurus, I decided to ask MM, and share his advice in case anyone else is having the same problem.
Here is what he said:
It is possible that your coolant sending unit is bad and sending false info to the ECU which is making the car run rich.
kowalski
  • El\' Duder
Engine not well
« Reply #2 on: January 29, 2007, 03:45:48 PM »
bump, and this causes backfiring?
Sale:
Fore Sale Thread
RED IS 91
Engine not well
« Reply #3 on: January 29, 2007, 07:34:55 PM »
First thing I'd check would be the Idle Control Valve . Then the MAF  . then the Idle position switch . in that order.
