Author Topic: aftermarket sterring wheels  (Read 6701 times)
jfdublyu
« on: April 28, 2006, 09:40:01 PM »
does anyone know how many holes there are for the sterring wheel? I'm trying to find out what type of momo adapter i need. I have the airbag steering wheel.
2002maniac
« Reply #1 on: April 28, 2006, 09:59:32 PM »
one splined hole.  Get on ebay and search for " e30 momo adapter" I picked mine up for $45 shipped.  You will need that adpater and a spacer because the adapter is meant for a non-airbag steering column.
I have a Sparco 368.  Sexy
thumper3ld
  • fathead ***
« Reply #2 on: April 28, 2006, 10:22:34 PM »
This is what I got:
jfdublyu
« Reply #3 on: April 29, 2006, 11:29:59 PM »
cool thanx. i was looking at steering wheel on ebay, just search like "NRG red steering wheel" if you wanna see
jfdublyu
« Reply #4 on: April 29, 2006, 11:34:34 PM »
hey, i found a 15mm and a 25mm spacer on ebay, what's the smallest size that will fit? Or, what size do you have and where is the steering wheel in relation to the ol airbag one? same, farther, or closer? cause i would actually like mine to be a little closer than stock (i have shorter arms being only about 5'8")
2002maniac
« Reply #5 on: April 30, 2006, 06:01:02 PM »
The spacer you need is not for the wheel itself.  You put it in front of the adapter under the steering shaft nut.
jfdublyu
« Reply #6 on: April 30, 2006, 09:39:43 PM »
ok, but do i need the 15 or 25mm? if either one will work then i will go w/ the 25mm
2002maniac
« Reply #7 on: April 30, 2006, 10:00:31 PM »
please post a link to the auction.  I dont think it is what you need.
christophbmw
« Reply #8 on: May 02, 2006, 08:49:56 PM »
Quote from: 2002maniac
hey could you post a pic? im thinking about getting a sparco 370 but dont know how it will look. thanks.
enildeR
  • lol ur face
« Reply #9 on: May 04, 2006, 05:29:31 AM »
Quote from: thumper3ld
This is what I got:
Where did you buy that steering wheel from? If ebay, what BMW did it come out of?
jfdublyu
« Reply #10 on: May 04, 2006, 06:11:57 AM »
I don't know, where did you buy your spacer? can you find any link to one like it so I can see wht it's supposed to look like?
thumper3ld
  • fathead ***
« Reply #11 on: May 04, 2006, 06:25:28 AM »
Quote from: enildeR
Its the blackline steering wheel made by nardi that I got off of ebay. Im not sure if they came with any cars stock though.
Quote from: jfdublyu
The spacer he is talking about I believe is just a steering column ring. You can get one from the dealership for like 6 bucks. Dont remember the part # but if Febi Guibo can chime in, he may be able to provide it.
« Last Edit: May 04, 2006, 06:29:53 AM by thumper3ld »
2002maniac
« Reply #12 on: May 04, 2006, 05:13:19 PM »
I made it out of aluminum.  I dont remember the dimensions but you could just stack some washers if you're ghetto.
Febi Guibo
  • m42 reporter
« Reply #13 on: May 04, 2006, 08:35:42 PM »
It's tough finding the right washers... even in the ghetto!
you want a steering ring #32311120260
works like it was meant to be there
Support M42club.com !!
jfdublyu
« Reply #14 on: May 04, 2006, 10:08:52 PM »
thanks!
