Author Topic: exhaust manifold studs  (Read 3886 times)
jakeb
« on: January 12, 2008, 08:24:39 AM »
I am coming from the 2002 world...at least engine work...where you locktight in exhaust studs.  Do you need to do this with the m42?
jake
http://www.classicdaily.net - swapping this into that
http://www.blunttech.com - all your parts needs
« Reply #1 on: January 12, 2008, 04:11:09 PM »
Not really, but I do anyway. Not because I fear that they will back out, but more of a corrosion resistance thing. If there is Loctite on there, the likelihood that I will actually be able to remove them in the future is much greater.
BrandC
« Reply #2 on: January 12, 2008, 06:16:14 PM »
I just removed my headers, and the studs came right out! I'm not sure if this is a good or bad thing, b/c I only see exhaust NUTS being sold on parts websites.
Is it okay to reuse the old exhaust studs/nuts?
pbgd3skier
« Reply #3 on: January 12, 2008, 06:32:38 PM »
those are fairly common metric automotive studs.
You should be able to find new ones that are identical online or even at local auto stores.
1991 BMW e30 318i
1980 BMW R80/7
jakeb
« Reply #4 on: January 13, 2008, 07:13:28 AM »
Mine came right out when I took the header off and I could not get the nuts off.  I bought new studs and nuts from the dealer...
I will not use locktight
