I would imagine yours takes ATF fluid.
That is what mine uses.
If you pull the drain plug you will probably have red stuff come out.
Other possibilities, you could get this nasty stinky snot out of there, which would be gear lube.
I believe no matter what you have in there you can use Redline manual transmission lube (MTL) or any other good synthetic manual transmission fluid.
