Author Topic: trouble with horn  (Read 2604 times)
vfstyles
trouble with horn
« on: January 04, 2008, 10:13:22 AM »
i posted this over on bfc, however i wanted to see if anyone here could help
i have a 1991 318is that had a Mtech1 steering wheel. i removed this wheel and re-installed the factory airbag wheel. im having difficulty making the horn work. im wondering if i installed it correctly. i searched a few threads and found a bunch of people going from airbag to non-airbag but that is opposite of what i want to do.
from my searching i found someone mentioning a spacer and a plastic pin. i remember seeing a spacer on there but not sure about the pin.
if it helps any, the turn signal stalks return after steering to there normal position. trying to get my car to pass NYC inspection
thank you
vfstyles
trouble with horn
« Reply #1 on: January 07, 2008, 08:52:44 AM »
had some time to look into the horn issue further
i opened the hood and pressed the horn and could hear the relay working.  looks like i just need to replace the horns.
