Author Topic: E36 M42 Tranny question  (Read 3434 times)
Artem
« on: December 27, 2007, 12:48:12 PM »
Hey guys, would the getrag 240 fit in an E36 without any modifications?
Just wondering.
-Artem
________________________
Artem Lepilov
WPI Aerospace Engineering
Class of 2008
WarrenHBrown
« Reply #1 on: December 27, 2007, 02:08:11 PM »
Getrag 240 came in several flavors, 1 for the M10 320i and early 318i's.  Later they used a 240 with a different front housing for the E30 318is.  The transmission is an overdrive unit .8:1 in 5th.
The transmission should bolt up to the E36 M42 motor but I think it will slow the car down because IIR the E36 has a 1.1  5th gear.  I would expect the diff ratio in a E36 is ~  low to mid 3.x:1.   I think the E36 used a ZF trans so the length and mounting may be different, you may have drive shaft issues.
Warren
88 325iX
91 318is
95 525iT
Artem
« Reply #2 on: December 27, 2007, 02:09:59 PM »
The driveshaft issues is key. I just want to make sure it fits the car. I have the later 240 with the correct bellhousing :)
-Artem
Artem Lepilov
Class of 2008
nickmpower
« Reply #3 on: December 27, 2007, 06:28:23 PM »
yeah you need the e36 slave cylinder, and need to switch the selector shaft joint thing. also lossen the nut on the driveshaft and push it all the way back. And you gearing is going to be insanly short
Artem
« Reply #4 on: December 28, 2007, 01:10:25 PM »
Good too know that it will fit. Thanks :)
Artem Lepilov
Class of 2008
bar73k
« Reply #5 on: December 30, 2007, 11:44:40 PM »
fits 100% had one in my car for a short time, with the standard 4.1 diff ratio
the gearing is way to short.
as said need a e36 slave cylinder
mach schnell
  • does it fast
« Reply #6 on: May 30, 2008, 06:09:38 PM »
What is the advantage of using an E36 tranny in an E30 318is?
Wise Old Dog
« Reply #7 on: May 30, 2008, 06:55:45 PM »
Quote from: mach schnell;50326
You would be able to use a 240mm flywheel and clutch. I guess you could change the diff to match the e36 gears and it would work out the same as far as gearing goes.
charlesmarseille
« Reply #8 on: March 07, 2009, 07:44:18 PM »
does a m20b25(late 89+) fits an m42? got my 4th gear busted!
