Hello everyone,
Just wondering if anyone has had a similar problem to the following and how they may have solved it.
Basically it all started about 2 months ago when my fuel pump died. Took me a while to get around to replacing but have finally done that. Now i find i am geting no power to the fuel pump. I traced it out and the fuel pump realay is not getting the signal from the ecu to ground the coil. All other signals are there, and the alarm is on the other side of the relay.
Has anyone had any problems with the ecu not grounding the relay, Is there some possible reason that the ecu might deliberatly do this.
Oh its also worth noting that i had the car disconnected from the battery for about a month. Charged the battery up again and connected it back up.
Thanks in advance guys
Adam
