Author Topic: E21 Motor Mounts  (Read 7905 times)
thumper3ld
  • fathead ***
E21 Motor Mounts
« on: April 26, 2006, 08:23:20 PM »
These things rock. Much stiffer then original, and didnt have to cut any tabs to fit them. Mechanic did say that they were a bitch to line up with the motor though. These things make the car feel more crisp and the throttle feels tighter.
I also had a ton of other work done to it such as upper and lower oil pan gaskets, cracked subfram was replaced with a used one that was also rewelded to reinforce it. and valve cover gasket was changed. These things could have attributed to the crisp feel but I doubt it. I think these mounts are the main reason for the crisp feel and tight throttle.
johna
    • My BMW 3 Series Website
E21 Motor Mounts
« Reply #1 on: April 26, 2006, 08:42:04 PM »
Do you know what model E21 they are from or what the part number is? Any more comments on installation?
E21 Motor Mounts
« Reply #2 on: April 26, 2006, 08:44:00 PM »
Awesome, I'll opt for these when the time comes around.
thumper3ld
  • fathead ***
E21 Motor Mounts
« Reply #3 on: April 26, 2006, 09:33:05 PM »
Quote from: john318isau
The part number is 11 81 1 175 735, not sure what model they are from though. ordered them from bma and they were pretty damn cheap. Sorry, have no comments on the install since I didnt do it myself. I would've but had a shitload that needed to be done and didnt wanna lie under the care with nothing but a jack supporting the motor.  Anyway, all my mechanic said about them was that they were a bitch to line up.
johna
E21 Motor Mounts
« Reply #4 on: April 26, 2006, 11:28:45 PM »
According to http://www.realoem.com that part number is for engine mounts for the E24 6 series and E28 5 series.
E21 Motor Mounts
« Reply #5 on: April 27, 2006, 12:38:59 AM »
Maybe that explains why your mechanic had a difficult time installing them??
thumper3ld
  • fathead ***
E21 Motor Mounts
« Reply #6 on: April 27, 2006, 05:36:29 AM »
11 81 1 175 735:
Thats the part number I used at bma and thats the part number that kowalski gave me on another thread. I'll try and locate the thread and link it later. Either way,he got'em on and they work.
Jbrough
E21 Motor Mounts
« Reply #7 on: April 27, 2006, 09:47:07 AM »
How often should these be replaced?  I have the engine out my car and am thinking I should add this to the list of things I should do and buy.
nickmpower
E21 Motor Mounts
« Reply #8 on: April 30, 2006, 09:31:18 AM »
were they green? maybe they were m30 mounts.
I wonder how the e21 mounts compare to the m30 mounts
did you notice much added vibration?
thumper3ld
  • fathead ***
E21 Motor Mounts
« Reply #9 on: April 30, 2006, 09:55:58 AM »
nah they're black.
E21 Motor Mounts
« Reply #10 on: May 01, 2006, 12:01:34 AM »
I have heard that the M42 mounts are filled with silicon or something to absorb vibration. Hence real pricey compared to a chunk of rubber.
thejimlab
E21 Motor Mounts
« Reply #11 on: May 03, 2006, 12:52:53 PM »
bump, i need to know the answer to this
E21 Motor Mounts
« Reply #12 on: May 03, 2006, 01:28:22 PM »
What I want to know is what it did with the engine - is it higher in relation to its previous position, lower, the same?  I have that darned Sparco bar that I want to install, but I don't want to notch/grind my intake manifold to get it on.
E21 Motor Mounts
« Reply #13 on: May 03, 2006, 03:47:27 PM »
i believe the proper E28 mount is 85-88. the mount must be green to fit properly...the thread needs to trimmed a little bit so that it can clear. i had a mechanic install mine and i forgot to mention that they needed to trimmed, so it was somewhat of a pain to install, still do-able though.
*EDIT*
they must be E28 535i mounts!!
« Last Edit: May 03, 2006, 03:55:59 PM by dude8383 »
