Hey everyone,
I'm an Aussie with a 10/89 built 318i, had the M40, but now its got an M42 in it. Only completed the swap a few weeks ago and I absolutely love the engine; couldn't believe that with 5 people in the car it would still pull in 4th!
My mechanic (and long time family friend) says the engine came out of a wrecked E36 318iS, as well as a few suspension components and other bits.
According to numerous online VIN decoders, the VIN number on the ECU (which I can confirm came from the wrecked car) indicates the car was a 1990 E30 318iS, production date 04/90. The ECU# is the 0 261 200 175 which is the E30 ECU.
This leaves a couple of possibilities:
1. The engine is the E30 M42 and it was swapped into the E36 aftermarket
2. The engine is the E36 M42 but its using an E30 ECU
3. Australian delivered E36 318iS were using E30 M42 engines... the production date of 04/1990 doesn't make sense tho.
Heres the next puzzling factor, according to what I've read online there was no euro spec 318iS using an M42, and the locally delivered cars are all euro spec as I understand it.
I've been trying to look up info about the differing intake on the E36 engine but I can't find pictures that help me. If its not too much trouble, could someone post a photo of the E36 intake (if it is cosmetically different to the E30 inlet) as the one I'm currently using looks nigh identical to the E30 intake.
The knock sensor is different too understand... could I check if the engine has a knock sensor without opening it up, ie check for the presence of a signal wire running from the engine. It wouldn't be hooked up as the E30 ECU doesn't support a knock sensor correct?
I only just realised the discrepancy when I looked up the ECU# and I can't get in touch with my mechanic until the weekend; yes, I know he's the best person to be talking to having done the swap but I'm impatient lol.
Sorry for the long spiel but now I'm just plain confused and the collective knowledge of this forum is quite impressive
If anyone can suggest ideas for ways for me to figure out exactly what I'm running it would be much appreciated.
Thanks in advance for any help,
Jezza
